Page 1 of 3 123 LastLast
Results 1 to 40 of 90
    Established Member Two Rings adf's Avatar
    Aug 25 2015
    GT3 Touring
    California
    New engine going in
    Follow up from: http://www.audizine.com/forum/showth...ctured-engines
    After gauging oil consumption in my B7 at 1L per 300 miles or so, I had 034 Motorsport do a compression test and borescope. I was particularly concerned about cyl #5 oil fouling spark plugs quickly. Had also pulled a couple of misfire codes on #5 using vag.
    Here are the compression results:
    4 = 160, 8 = 155
    3 = 155, 7 = 150
    2 = 170, 6 = 140
    1 = 160, 5 = 135
    Also found excessive burnt oil build up in all cylinders and oil sitting on top of pistons. Cylinder #5 was particularly bad (no surprises there).
    So we are ordering a new engine from Audi. Will report back when it's in but that's probably about a month or so away.
    My butt dyno says the car seems to be running great, but with compression numbers like that and so much oil consumption, I'm guessing a new engine with better compression is going to run much better.
    2007 S4 Avant 6MT, Dolphin Gray, APR Exhaust, 034 motor mounts, control arms, rear sway
    2019 GT3 Touring
    gallery
    Jul 21 2008
    Phoenix
    Whoa, what's the price tag on a new engine from Audi? Did you get a long block, or just a short block?
    Dec 07 2009
    East Coast
    Last I've seen posted prices on new short block from Audi was somewhere in the neighborhood of $10k, and slightly over $13k for a longblock. I wonder what Audi charges these days, so same question^ hopefully you don't mind disclosing. Have you confirmed is it's going to me remanned one or brand spanking new?
    Forget the B8, keep the V8!
    Aug 25 2015
    GT3 Touring
    California
    Quote Originally Posted by tymeks View Post
    It's a long block, part # 079100031DX for just under $13k. Was told by 034 that Audi had some problems a while back and doesn't do the short block any longer. This one comes with a 1 year, 12k mile warranty.
    Quote Originally Posted by Mr.Wrong
    Supposedly the engine is brand spanking new. There is a core to be returned though so I suspect it may not be a newly minted block.
    2019 GT3 Touring
    gallery
    Dec 02 2014
    Dallas, Tx
    Wow, spending 15k on putting a brand new stock motor in a car that on a good day is only worth 15k has got to be the smartest thing I've heard in a looooong time.. You must be a dealership's wet dream.
    Jul 21 2008
    Phoenix
    Quote Originally Posted by WCCoffey View Post
    To each there own. So get off his balls. No trolling needed here.
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    Whoah, that's a chunk of change . That's commitment, I will give you that. Are you going to add some mods before you put it in?
    Aug 25 2015
    GT3 Touring
    California
    Heh, well if we all optimized for rational, financially responsible decision making when it comes to car ownership, we would all be driving toyota corollas. Not Audis, and surely not S models.
    I'd trade up for a new S4 or a Golf R but I don't like either of them anywhere near as much as this car. And if I've learned anything in my history of car ownership, it's better to spend money on a car you love than to rationalize spending it on a "better valued" vehicle you are ambivalent about. Not that any of us need to justify our choices in cars, especially here, but that's mine.
    2019 GT3 Touring
    gallery
    Aug 25 2015
    GT3 Touring
    California
    Quote Originally Posted by s4ski View Post
    Not much really. I am putting in the 034 control arm kit and motor mounts though while the engine is out.
    2019 GT3 Touring
    gallery
    Dec 02 2014
    Dallas, Tx
    You're absolutely correct... but spending that kind of money for no gain is kinda like beating your head against the wall. IMO, spending that kind of money on a car and keeping it stock is solely for cars that will appreciate in time or are considered a collectable car that wont continue to depreciate massively like our cars will.
    Spending 15k+ could have netted you a JHM built motor with a Supercharger Kit. Then you'd have a reliable motor that doesn't burn oil and makes like 500hp... Seems like a much better investment considering cost vs. reward
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    I gotta say I don't understand why people are panning him for this, I totally get his point of view. I love this car, and can't really see another that I rather have at this point, so I for one understand this, and I'm glad the option is still available.
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Hey, man. It's your car. Do what makes you happy. If, in the future you want to make changes, you can.
    Old Geezer, formerly known as Stud Muffin
    Aug 25 2015
    GT3 Touring
    California
    A JHM motor is intriguing. Not necessarily for the power gains, but the fact that they sleeve the aluminum block. I wonder what their waiting list looks like. Saw a reference to a total bill of around 30k for a built engine + SC setup from them.
    2019 GT3 Touring
    gallery
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Yea i would've atleast put that 13k torwards a built block incase later down the road id want to add a blower especially with all these other new cars jumping up in power.
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    I saw ebay brand new one for $10K. Should those tensioners been replaced with updated JHM parts before put engine in?
    B6 Noggy Avant, B8.5 Allroad
    Aug 25 2015
    GT3 Touring
    California
    Quote Originally Posted by hkdolphins View Post
    I think I saw the same one and discussed it with the service dept at 034. Looks like an engine built by Overland but I wouldn't get a labor warranty from 034 getting the engine third party from eBay. So I decided to go with a factory motor.
    That's a great point. Any pointers on the increased durability of the JHM tensioners?
    2019 GT3 Touring
    gallery
    Dec 07 2009
    East Coast
    Quote Originally Posted by adf View Post
    See that X at the end of a part number, iirc it stands for remanufactured. I'd do some digging just to confirm this.
    Great minds think alike. Couldn't have said it any better.
    $15k would not yield you a built motor with sc. That's quite an optimistic number. Built bottom alone is $10k, add to that their hd heads then add their charger and a must have supporting mods. A bit more than $15k wouldn't you say?
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Quote Originally Posted by Mr.Wrong View Post
    Yea, it would be around $22 grand all told purchase the engine, supercharger kit, and install if you arent doing it yourself. Add in miscellaneous freight fees if you are sending your engine to them
    Dec 07 2009
    East Coast
    ^I see a withdrawal kicking in
    Jan 14 2009
    Audi's
    OP i couldn't agree more!!! I debated over investing the money to rebuild my heads and timing etc VS. getting into a new ride and after test driving a the new offerings from Audi and VW i wasn't impressed. So I bit the bullet did a rebuild added a few new mods and couldn't be happier!
    Quote Originally Posted by Guitarmageddon View Post
    It would be more than 22k for parts alone not to mention you have to ship your car if your not local so add another 2-4k for that.... then they do the install and break-in at their facility. When i reached out it was roughly 30-35k for a stage 2 hopefully the price comes down eventually!
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    OP, do you have a warranty?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Aug 25 2015
    GT3 Touring
    California
    Quote Originally Posted by LINDW4LL View Post
    No warranty unless a previous owner had one. Can you still buy a warranty?
    2019 GT3 Touring
    gallery
    Aug 25 2015
    GT3 Touring
    California
    Quote Originally Posted by Mr. Corey View Post
    Pretty steep but still cheaper than trading up to a new S4. Maybe once this new motor goes south in a few years this would be a good path. But hopefully we get a decent new RS model in the states before then :)
    2019 GT3 Touring
    gallery
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    Just wondering why someone hasn't found a machine shop to sleeve the block for them and use stock pistons and rods, or get a set of forged internals.
    -Tim
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Respect
    If nothing else, I would install headers before dropping in the new engine. The S4 will never match the RS5, but nows the perfect chance to transform the sound and add some low end torque.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Aug 25 2015
    GT3 Touring
    California
    Quote Originally Posted by melomandn View Post
    The JHM longtube headers require cat removal though right? Don't think I could get away with that in California. Was thinking about doing a JHM intake manifold though.
    2019 GT3 Touring
    gallery
    Jan 14 2009
    Audi's
    you can order your test pipes with your headers however you like. I would highly recommend them in combination with IM they really transform the car!!! Maybe even show your stablemate whose boss lol
    Nov 11 2008
    Theres a shop i found that claims they'll sleeve our blocks for 2800
    Nov 11 2008
    Dec 07 2009
    East Coast
    IIRC wasn't there another member claiming he found a shop to sleeve his BHF and going to do it... Will they warranty their work?
    Mar 13 2007
    Sunny UK
    I'm interested now. This plus a low-pressure blower could be very fun. I've also been told that 2.7t rods are dimensionally identical to 4.2 engines. Someone needs to confirm this though.
    -Tim
    Jan 14 2009
    Audi's
    Quote Originally Posted by sandspeed View Post
    034 sells rods for are cars
    https://store.034motorsport.com/paut...l-4-2l-v8.html
    Mar 13 2007
    Sunny UK
    Quote Originally Posted by S4orgy View Post
    I've been chatting with them, and they've done it before. I'm planning on doing this when I get back from a long business trip I have coming up. They also recommend going with Wiseco or Arias pistons and they will bore the sleeves to match.
    And IE has some for nearly half the price.
    http://www.performancebyie.com/integ...154x21-vw-audi
    -Tim
    Dec 10 2011
    CLT | MKE
    4.2 and 2.7T rods are exactly the same to the best of my knowledge. I've heard this stated many times in the past, and both are 154x21 and have 100% identical specs on Integrated Engineering's site.
    -Hayden
    Aug 25 2015
    GT3 Touring
    California
    Any thoughts on cracking open the new engine and adding the updated JHM timing guide while the engine is out? How difficult is this piece to swap out on a bare motor in terms of labor? Sounds like the part is only $60 from JHM but worried it may take a lot of labor time to swap the part even with the engine already out.
    2019 GT3 Touring
    gallery
    Dec 07 2009
    East Coast
    Most of the labor on a timing service comes from actually pulling and reinstalling the motor. So once it's out it shouldn't take much to install new guides. Definitely a must do once your motor is out for whatever reason.
    Aug 25 2015
    GT3 Touring
    California
    Now for the catch 22 -- do I swap out the sprockets and updated guide and risk voiding the new engine warranty. Or do I leave this job for later knowing that in 50-100k miles I'll need to pull the engine again.
    sheiße...
    2019 GT3 Touring
    gallery
    Aug 25 2015
    GT3 Touring
    California
    I am curious if anyone has experienced timing failures on a relatively recent remanufactured Audi engine.
    2019 GT3 Touring
    gallery
    Dec 07 2009
    East Coast
    sheiße...
    Catch 22 indeed. What does their warranty cover, mileage/timeframe?
    Aug 25 2015
    GT3 Touring
    California
    1 year / 12k miles
    2019 GT3 Touring
    gallery
