Results 1 to 11 of 11
    Established Member Two Rings spy963's Avatar
    Jul 30 2014
    B8.5 S4 & 997.2 Turbo S
    Montreal
    Disable suggested gear indicator?
    Is it possible to disable the suggested gear indicator without vcds?
    I have a 6MT.
    2013 Monsoon Grey /S4 : 6MT : Unitronic Stage 2++ : 58.3mm/186mm : PLM Heat Exchanger : Sachs XTend Clutch kit : Eurocode TRUfit Intake System : Bilstein B8 Shocks / H&R OE Sport Springs : Custom X-Pipe w/ AWE 102mm Exhaust tips : 034 Transmission Mount : CR-15 Strut Tower Brace : AG black M510 19x9.5 : ECS CF Decklid Spoiler : CF Mirrors
    Jun 20 2015
    NC
    I believe it's a setting in the MMI. I am about to go check.
    Jul 30 2014
    Montreal
    Quote Originally Posted by Sceanzo View Post
    Ok thanks, let me know if you found something!
    Jun 20 2015
    NC
    Found it.click on Car. Then instrument cluster. Then shift suggestion off
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    It's a nice feature though (not for the gear suggestion but for confirmation of selected gear)... and it's small in the display not to really be a nuisance.
    Jul 30 2014
    Montreal
    I don't think I have "instrument cluster" option...
    My options are:
    Car system or set to individual
    Then...
    Vehicule settings
    Driver assist
    Ac
    Servicing and checks
    Jun 20 2015
    NC
    Take a picture
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by MrFunk View Post
    Same, I like being able to glance down and double check what gear I am in without having to wiggle the stick to figure it out.
    OP, you can disable it in mmi, but you can also keep it, but turn off the green shift suggestions. For that you need to disable the economy features.
    2021 Audi S4, P34 Intake
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by spy963 View Post
    My options are:
    Then...
    Vehicule settings
    Driver assist
    Ac
    It might be part of the "hidden" menu that must be unlocked with vagcom to access?
    Jul 30 2014
    Montreal
    Take a picture
    Here's my options when I click on "car systems"
    Do I need to use vagcom to disable the green shift suggestion?
    Mar 21 2015
    Or Carista
