Results 1 to 9 of 9
    Senior Member Two Rings AWD Addict's Avatar
    Nov 06 2013
    Livermore, CA
    Having trouble getting ashtray out
    I've got the shifter cover pulled back and those two 8mm bolts off but that dang ashtray just doesn't want to come out. I don't want to force it either. I searched and it sounds like it might be best to remove the climate control unit but I'm having one helluva time finding a DIY anywhere. Has anybody who's removed their ashtray got a few good tips or maybe even a good how-to with pics?
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    You need to take out the HVAC controls, and it's really not a big deal at all. Take a look here (under "Power Switch" section) where I had to do it for my then Laser Interceptor install.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Quote Originally Posted by AWD Addict View Post
    Yeah... this is a bitch... Hard to get out and in but I managed to do it without removing the HVAC controls. However, it's probably easier if you just remove them
    Nov 06 2013
    Livermore, CA
    Quote Originally Posted by S4Per View Post
    Thanks for the link. Always appreciative of those who take the time and energy to write them up. Which makes it EXTREMELY frustrating when I come across a critical step with instructions that are a little confusing...
    "...Disconnect the HVAC head by pressing down on the tab you'll see on the 4 left ones, and in on the sides of the furthest right one..."
    Veteran Member Three Rings outsider6661's Avatar
    Jul 02 2007
    2008 RS4, 2016 S5 Black Optics
    Markham Ontario, Canada
    If you have the factory rsne that will need to be removed first so you can properly remove the hvac then you can finally remove the ashtray!
    Sent from my SM-G900W8 using Tapatalk
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    don't you just love working on these cars lol
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Feb 17 2004
    2013 Audi S6
    Thanks for the link. Always appreciative of those who take the time and energy to write them up. Which makes it EXTREMELY frustrating when I come across a critical step with instructions that could have been written by a 4th grader...
    I'm sorry but WTF?!?!? I've been working on this thing for a while and if this doesn't make sense to me it just isn't being explained very well.
    I get you're frustrated but, you could forget the 4th grade stuff and try "Thanks for the help, but hey, this sentence doesn't make any sense to me, can you clarify?" next time instead.
    I try my best to document clearly, but no doubt, you discovered a crap sentence there :) Seems like 2 edits of mine crossed each other. I'll fix that later.
    As outsider said: remove the RNSE, and it'll come out very, very easily. From my write-up, "Next, remove the HVAC head unit. It's retained fairly loosely by 4 metal 'bridge' clips. I barely had to pull at all to get it out." The f'ed up sentence is about the electronic connector holding it in place, which you'll figure out how to disconnect once it's loose.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Nov 06 2013
    Livermore, CA
    Sorry man. Poor choice of words. I didn't know you were the one that took the time to put that together. Thank you very much though. I think the problem might be that I have factory RNSE and, as a result, it's not possible to remove the HVAC without taking it out first.
    Feb 17 2004
    2013 Audi S6
    No worries, all good. And yeah, I think you're right. I'm also pretty sure that you just need to slide the NAV forward a bit, and not take it all the way out (95% sure on that).
    Never forgotten:
    2002 S4 Stage 3 Tip
