Ive been dealing with the same issue, have had three alignments done and the car still continues to pull left with the steering wheel having a lot of play especially on freeways. This all started when I put new wheels and tires on the car. I have 034 adjustable upper control arms and the alignment done at three different reputable shops which leads me to believe it's not an alignment issue. Looking into new tires now hoping this will cure the pull and help the car feel more planted, with the stock wheels + tires the car felt glued to the ground. Bums me out because the set of tires currently on the car are relatively new and spent $1k on them. Current set up is vmr 810's on Hancook ventus evo 2, 255/35/19. Hoping if I put Michelin pilot super sports on it will fix the problem but with no guarantee of a cure, I am not sure I should go this route yet. The car is on vogtland coilovers, full eurocode sways + links, and alu kreuz, so it should handle great, but the steering issue and continuing to have to recorrect has kind of ruined the experience. If anyone has any other suggestions they would be much appreciated.
