Originally Posted by
MrBigglesworth
How did you get on fixing your issue?
Report back to the group. In my case, we thought it was my O2 B1S2 sensor. Actually I was not sure it is pre-cat or post-cat, as B1S1 reading (mA) has corresponding spikes, thus which causes which. Around the same time, I noticed I had oil leak around filter housing - I knew it is oil cooler and/or filter housing gaskets. Since I was due for an oil change any way, I thought I would seaform fuel tank and crankcase, change gaskets and oil/filter, then put on new O2 sensor (in that order), so as to keep new O2 from any seaform contamination (I know they claim O2 sensor safe, but still).
Now 400 miles after gaskets/oil/filter change, CEL never come back! Pull a log, LTFT is at about 6-7%. I guess I am good now. However, I am puzzled how oil cooler/filter housing gasket leak can throw LTFT off and P0171 CEL on.
Take a closer look at B1S2, I still see the occasional 0V reading. It seem my O2 may still need a change, but it does not seem it is as bad as throw LTFT off and CEL on. I will continue monitor it.
