Results 1 to 9 of 9
    Apr 02 2013
    above top secret
    Touareg coil spacer
    Hello,
    Does anybody want to share the experience using the touareg spacer to accomodate the 2.0t coil packs? How's the fitment? Does it hold since it seems that it does not have holes for the mounting bolts?
    The reason I'm asking because i saw someone took a picture that the ECS spacer (the small pieces) does not align with the bolt hole on the valve cover.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Should work fine. They do not fully cover 2 of the corners so put a dab of silicone on there to keep crud out.
    The tabs that poke into the bolt holes are prob one time use and never coming back out.
    Some have removed them and drilled holes to use bolts.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Mar 06 2015
    2004 F150
    NOVATO, CA
    I am about to go this route also. I want cheap and functional. After reading several threads about adaptor plates I came to the same conclusion about the little plastic tabs.
    If I can dovetail this thread: I read somewhere that Toureg 1 V8 coils seal to the valve cover better because they have revised rubber boot. I wonder if anyone can verify that they work on AEB.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    You only really need adapter plates for early AEB heads. For later valve covers you can cut the rubber base off your old coil. Slip it on the new coils and it will hold it fine.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    I never ran adapter plates on my 97. It worked fine.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Apr 02 2013
    above top secret
    Hi King_,
    Does the coil snaps in place to the plugs? Will the top plastic cover fit in to ensure everything holds down better?
    Oct 09 2012
    Quote Originally Posted by maxiz1 View Post
    Hi King_,
    Hi Maxiz.
    Yes they basically snap onto the plugs. They will NOT help hold them DOWN better. I push them on most of the way then lightly hammer fist the last bit on. The top plastic thing wont really do much, maybe keep debris out of the holes. I never had a problem. If you do buy them drill them out so you can use the screws.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Jan 16 2006
    LA CA
    I really don't think the Taureg adapters are a good design.
    http://www.audizine.com/forum/showth...oil-Conversion
    Veteran Member Four Rings Murph_129's Avatar
    Dec 15 2014
    Indianapolis, IN
    Hi King_,
    Quote Originally Posted by King_ View Post
    Hi Maxiz.
    Can't remember who it was I saw do this.. But they took the boot off of the old packs and slid them onto the 2.0coils below the original rubber seats... Offsetting them down enough they seated as normal.
    -Murph
    11' A4 2.0T Quattro Premium+ Phantom Black - IE Stage2
    01' A4 1.8T Quattro Sport Silvaro - DazTuned Stage2 - SOLD
    IG: smurphy_iii
