Results 1 to 40 of 43
    Sep 14 2005
    NC
    F21 and solomotorsports.
    Has anyone ever used solomotorsports??
    Any opinions??
    Also what's the deal with the f21's??
    Better than k04s??
    Rather do it right the first time.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    There's no right way really.
    Genuine k04's are tried and true, will make good numbers and be reliable.
    F21's are proving themselves, will make good numbers and seem to be reliable.
    Doing it "right" is going to come down to the quality of workmanship on the install.
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by ajee622 View Post
    Better than k04s??
    F21 is a K04 hybrid. It is different than a K04. 'Better' depends on what your goals are, which you've not given.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I would suggest you consider how the car will be driven most of the time and base your turbo decision on that, not on a dyno number.
    It seems the cool thing to do here is get the biggest turbos your engine will support, or even worse, get larger turbos than your engine will support, and dial them back.
    The price you pay is it doesnt look like these big turbos do a whole lot below 5k.
    Now, I usually cruise around at 2.5-3k.
    They dont need to be spooled at that rpm, but when I roll on the throttle, I would prefer not to wait 2000rpm for something to happen.
    This is k04 or f21 territory, both solid options. They are better mid rpm, but they do give some up to the larger turbos in the upper rpms.
    I went with f21s because $$, a few more ponies than k04s, seem to have a decent track record, and Doug is absolutely top notch when it comes to customer service.
    I chose to focus on improving the areas I most often find myself in and ended up with a great dd, and then some.
    If I wanted to decimate all at racewars, I would def have gone different route. Prob giant turbos that didnt spool until 5k, and a clutch that you wouldnt wish upon your worst enemy in traffic
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Sep 14 2005
    NC
    Ok yeah so this car is my daily driver. Not looking for anything crazy. Just some spirited driving to work and on the weekends. I'm willing to spend the money but let me give an example.
    For k04s I'm estimating close to $7k installed. Looking at awe or 034 kit.
    F21s looking at maybe around $5k.
    If the $2k difference means I have 50 less hp I can live with that.
    I just don't want to go the f21 cheap route and the turbos go because they are some cheap Chinese turbo.
    Not sure if it all makes sense but this is what I'm thinking.
    Nov 16 2010
    WetSide, WA
    You save 2k and (likely) gain 50hp with f21s.
    There are dynos posted of k04 and f21 cars you can compare to see what suits your driving style best.
    I really suggest you do this. If I had to decide between the current versions, I might have gone with the k04s for a dd.
    Nov 02 2014
    Winchester, VA
    Where in PA are you located? I'm in Winchester, VA. If you aren't too far and want to see what f21's are capable of, I'm all for giving rides.
    Nov 02 2014
    Winchester, VA
    Also, I have turbos that were heavily abused for 15k before being removed. Installed them on my car, and have been running them at 24-26psi (temp dependant, mostly 25psi) for 10k now without issue.
    The car is fast, and fun. Overtaking on the highway at 70mph is fun in itself without shifting out of 6th. Lots of power, great broad power band without sacrificing gobs of low end torque.
    Nov 16 2010
    WetSide, WA
    That is prob the best way to do it
    But on the location thing, I am closer to you than he is
    Think he is actually down south somewhere.
    Jan 06 2007
    Mk7 Golf R
    FL
    Here's some notes I made of the original F21 vs K04. Frankenturbo now uses a different compressor wheel and mixed flow turbine on the F21, but I don't think the general trends of my initial comparison have changed much.
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    I've been to solo when I lived in ATL, good bunch of guys. Don't know anything about their tunes but I know plenty of people run them.
    I have a Daz tuned f21 car in KOP, if you're close I'd be happy to give you a ride.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Jan 17 2015
    2001 Noggy S4
    toledo, OH
    Flyboy, ive seen alot of your work, been to your page multiple times over the past year or two. I can tell you guys LOVE twins, but what do you think about singles? Seems like a precision 5858 would do the job with same spool time and a way cleaner (at least more simple) IMO set up.
    Sep 14 2005
    NC
    Quote Originally Posted by DieselElectric View Post
    Yeah I need to update my status. I'm in Charlotte nc
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Quote Originally Posted by incontrol7 View Post
    And spend more money. Seems that most people that tried single turbo life are either still stuck building them, or given up completely. There's really only a few solid single turbo cars out there running. I say stick with twins.
    Sep 14 2005
    NC
    Quote Originally Posted by 01audia4 View Post
    If I come back up to Philly soon I might let you know. Grew up like 20 min from kop
    Jan 17 2015
    2001 Noggy S4
    toledo, OH
    Quote Originally Posted by Peter1.8t View Post
    How do you figure more money?? Stock 2.8 manifolds and a custom up pipe and down pipe, then intercooler piping? Less money on piping, oil and coolant lines, less fittings etc... idk maybe its just me. I mean I dont like the idea of them being right up against the firewall behind the motor but it does look bad ass IMO.
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    Have had good experience with solo's guys, they know what they're doing tuning wise. Have come a long way in the past couple years.
    01.5 Imola S4. Stage 3 F21's/To much to list
    Senior Member Three Rings s4chiro's Avatar
    Dec 30 2011
    2011 VW TIGUAN
    chicago
    Quote Originally Posted by FlyboyS4 View Post
    how do f4s flow compared to f-21s? have a brand new set ready to be installed
    2000 Imola B5 S4 /MeowIsFat TUNE/ SSAC 3"/ NEUSPEED EXHAUST/ NEUSPEED S/S/ H&R SPORT/ VMR 708s--SOLD :(
    2009 C6 A6 PRESTIGE/ APR STG 2 TUNE 93:100oct/ APR PULLEY/ 3" Custom Magnaflow/ USP CAI/ 19" Peelers
    Dec 03 2009
    PNW, Washington
    If you can fab then it's probably cheaper, but most people can't and end up spending a ton of money.
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    Project B5 STK: $899
    Tial Wastegate: $265
    Precision Turbo: $1000
    Even if you buy everything, I still don't think it adds up to that much more than a twin setup..
    Granted, I didn't include all other supporting mod. However, for the basic setup it seems to be only a bit more expensive , if not the same "general" cost in the end.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    A lot of people miss out on just how much r&d the factory does for heat management and structural integrity. Add a single turbo in back and be sure to cook all sorts of things. You need to wrap up all the wiring and different sensors, etc. It's a lot of trial and error and fix as things fail that gets overlooked.
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by s4chiro View Post
    Between those two I like the F4H better for the K04-like spool, but I don't know which flows more.
    Feb 05 2014
    BROOKLYN
    Quote Originally Posted by slow ride View Post
    Not true dude. My friend's single turbo car has been running for over 6 years I think. Nothing is wrapped up and he hasn't cooked anything but breakfast each and every morning right before he drives the car every day.
    Registered User Three Rings SoloMotorsports's Avatar
    Nov 05 2013
    United States
    F21's combined with Solo Tuning is a GREAT idea
    Jan 06 2007
    Mk7 Golf R
    FL
    Better than k04s??
    Another option is the SRM RS4+, it's also a K04-hybrid.
    Aug 24 2014
    Newport Beach, CA
    It's a shame there isn't more info or real world reviews on them.
    2024 M3 Comp xDrive
    May 20 2012
    San Jose
    Quote Originally Posted by christianb5s4 View Post
    Do they even really exist? I haven't seen anyone post about actually getting a set. In fact someone recently tried to buy a set and got steered toward the (misnamed) K24s instead.
    Jan 06 2007
    Mk7 Golf R
    FL
    I agree, I'd also like to see more on the Mixed Flow F21.
    I have seen one log from the SRM product and it looked promising, but that's just one data point.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by oppositelock View Post
    I saw that thread, for me personally K04 framed turbos fit my needs the best so I was slightly bummed when they went for K24s instead.
    same with the PB5 variant of the K04 hybrids, especially because those are really pretty ideal turbos for this car if you aren't looking to build the motor. Still spools like PJ K04s, but has another 50hp in potential output.
    2024 M3 Comp xDrive
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    OP -- if you have any questions about our MixedFlow F21BT turbochargers, feel free to drop me a line at [email protected]. Thanks again to the community for its continued support.
    dh
    Jan 06 2007
    Mk7 Golf R
    FL
    Have you seen evidence of that? I haven't seen proof that any of the currently available K04 hybrids spool like BW K04's.
    Sep 14 2005
    NC
    Quote Originally Posted by Doug@FrankenTurbo View Post
    dh
    Thanks. Kind of pricing everything out and doing homework before going stage 3. Who knew so much would be involved.
    Oct 19 2009
    Portlandish
    Well, it's not like we didn't test for the question. Here are some graphs we posted here early last year:
    These logs were collected in 3rd gear -- which nets slower boost onset than you'd see in 4th gear logs -- but I think they demonstrate good responsiveness. They did to me, anyway, and these data were enough to persuade me to put the MixedFlow design into production.
    Jan 06 2007
    Mk7 Golf R
    FL
    I'm undertaking to see if there is something available that has K04 responsiveness, plus a few other characteristics. I have not yet found a turbo option that meets the responsiveness criteria, but I'm not assuming I am aware of every option out there. The mixed flow F21 is a solid turbo, but it doesn't appear to have K04 response, I doubt the PB5 option will either.
    Dec 10 2013
    Borden, Ontario, Canada
    Got a line for a set of Frankenturbo F4H turbos. Brand new unused and never installed. Was it you that was looking for a set? I don't remember
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by Bordom View Post
    That would be tempting if I hadn't already collected a good bit of info on them. I like the F4H a lot.
    Veteran Member Three Rings sjmelling's Avatar
    Jan 06 2010
    Winchester -> Centreville, VA
    There are several different setups running around the Winchester area. If you come down, I'll show you what a super basic F4H car is like. There is a basic PJK04 build and of course DieselElectric is running F21's. Also, if your timeframe allows there is a S4 meet in Philly in May where you will be able to see everything from Stock-ish to fully built motor big turbo cars.
    In the relatively limited driving I have done on them, I like the F4H's quite a bit as well. My favorite setup that I have owned was the PJK04's, but the F4H's are gaining ground the more I drive the car.
    I really don't think you will be disappointed with any of the K04 framed options with appropriate supporting mods.
    Stephen J Melling
    2001.5 Audi S4
    ~~Laser Red Stage 3, Rods, F21's, other stuff and things
    2000 Audi S4
    ~~Hibiscus Red, Silver Interior, 01E, stock AF
    Dec 10 2013
    Do you have logs comparing F4H to the new Mixed Flow?
    IG: 24_et
    Sold:
    RIP:
    Jan 06 2007
    Mk7 Golf R
    FL
    I haven't personally used the F21 as I have the F4H. I have a bunch of logs from the F4H's I used, but I'm limited like everyone else to what gets made available by people with the F21's.
    Oct 19 2009
    Portlandish
    Well, the Smoking Tire's Matt Farah seems to like how these turbos perform.
    Gabe, the car owner, was one of our very first MixedFlow customers. Congrats to Solo for being today's feature on this influential web series!
