    Sep 27 2015
    Prov
    Will 3.0 heads fit a 2.7 block?
    Ive heard they do I have heard the don't whats the truth? I looked at the head gaskets couldn't tell if they were exactly the same.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    They are not a simple drop-in like 2.8 heads are. There are ECU issues with the 3.0 cam adjusters and 2.7T ECU, too.
    Stick to 2.7 or 2.8 heads
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    May 16 2008
    South Texas
    They will bolt up but that's the easy part.
    Sep 27 2015
    Prov
    But have a 3.0 L car I want to put the 2.7 block would that create less issues?
    Sep 15 2014
    92 Ford Bronco 351 windsor. 2000 Subaru forester. 89 Ford bronco 351
    United States
    good question!! i found an a6 with the 2.7 andi have a b6 3.0 but the 2.7 has bent valves. would it be easier to fix the valves or swap heads/crank blah blah blah
