Results 1 to 25 of 25
    Dec 23 2012
    New York
    Any down side to removing those restrictor fins in the airbox ?
    Hi. I went to install my K&N filter and noticed this plastic insert of fins restricting airflow. I removed it. Drove the car twice since, no fault codes.
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    It is a snow-grate, so not unless you live in an area with snow. It is restrictive.
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    Mar 21 2015
    If you have an open element air filter it definitely helps keep the engine bay clean.
    Dec 23 2012
    New York
    I see. I do live in an area with some snow. I'll try driving once in snow (with it removed) and check if any water got on the filter itself...
    Mar 20 2012
    Sydney, Australia
    2016 S3 SB
    2005 B6 S4 Avant Tip JHM'd [SOLD]
    2004 B6 S4 Man JHM'd [SOLD]
    Aug 06 2012
    san diego
    how would the part pictured above help keep the engine bay clean?
    Mar 21 2015
    Quote Originally Posted by markn1689 View Post
    I was thinking it was a snow screen like on the S4. I don't see how that thing in the pic is a snow screen.
    Aug 06 2012
    san diego
    hmm i think im gonna goto my garage and remove that thing. im in cali and have no need for a snow shield. nor do i see how this would keep snow out anyways
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Let me know how that works out with the stock air filter.
    -cW
    Sent from my SM-G900V using Tapatalk
    2023 X3 M40i Alpine White
    Established Member Two Rings m3brad's Avatar
    Jul 22 2014
    Midwest
    -cW
    I'd also like to know.
    Aug 06 2012
    san diego
    before i remove it i was wondering: does this plastic part hold the filter in place? does it have any other function other than to restrict and prevent snow.
    Jan 01 2016
    Rockford IL.
    It would like to know it's purpose, Audi did not place it there for no reason.
    Any one know if it is for sound deadening?
    Mar 30 2015
    Australia
    It is a snow-screen. See 13 in photo.
    Aug 06 2012
    san diego
    Quote Originally Posted by roadrunner_oz View Post
    ok thanks. heading to the garage now
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Any more feedback on this? How did it work out?
    -cW
    Aug 06 2012
    san diego
    no i actually did not remove it. im still wondering how this part helps to keep snow or water from going anywhere. if it sits under the filter wouldnt the filter get wet anyways?
    what is the deal with this part. how does it prevent snow?
    Established Member Two Rings MathildaS3's Avatar
    Apr 14 2015
    Palm Beach Gardens, FL
    Removed mine months ago with no issues. I really can't think of a good reason for the part being there...considering Audi's nomenclature for 'restrictive plastic screeny thing'.
    Nov 12 2015
    Are there even any noticeable benefits to removing it?
    Mar 30 2015
    Australia
    Because air enters from the bottom, then filtered and exits at the top. It is there to stop the air filter from getting wet (like a splash guard). I drove in very heavy rain for a few days last week and no water gets in.
    Mar 30 2015
    Australia
    Quote Originally Posted by three_quid View Post
    None
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Sounds like there isn't any benefit to this mod then...
    Most intake mods are for show and sound anyway.
    -cW
    Mar 30 2015
    Australia
    -cW
    Agree. The intake isn't a bottleneck on most turbo cars.
    In theory you'll get more airflow and a bit more sound, but not 'noticeable' IMO. I just left it removed.
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    I pulled mine this weekend and dropped in an AFE filter. I do have a little more intake sound, but it's been so cold and my commute is so short, I haven't been able to really stomp on it to see if I notice a difference in any way.
    2016 Monsoon S3
    My slow build link - Onequick4door
    Jan 12 2016
    Los Angeles, California
    I removed the "snow grate" on my S3 with a stock air filter and I wouldn't say there is any significant performance benifit, but it is noticeable (to me at least). One thing I have noticed is that the boost guage is showing a little more boost throughout the RPM range than it did before the modication.
    Overall, if you're living somewhere where it won't snow, I don't see any reason not to make this simple modifcation.
    2016 Monsoon Grey S3 P+ w/ BO, Resonator Delete, AWE Resonated Catted DP, Unibrace UBQ, 034 Rear Sway Bar, 034 Dogbone Insert, 034 Rear Subframe Inserts, 034 P34 Intake, CTS Turbo Inlet, ED Springs, Eurodyne ECU and TCU
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    Quote Originally Posted by onequick4door View Post
    Finally was able to jump on it and I felt slightly better response and oomph from the motor.
    2016 Monsoon S3
