Results 1 to 17 of 17
Thread: Code P0087
    Veteran Member Three Rings awwturbo's Avatar
    Mar 22 2012
    2009 BMW 328i Xdrive sedan, 2010 Aprilia RSV4 R
    Northeast USA
    Code P0087
    So, i did a search on this and most of the results are from B7s. Was hoping to get some feedback from B8 S4 owners on this issue. Driving around today the car totally fell flat on its face while accelerating. No CEL came on and felt like massive misfires.
    Here is what I pulled from Vag-Com when I got home:
    3 Faults Found:
    6238 - Fuel Rail/System Pressure
    P0087 00 [101] - Too Low
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 70798 km
    Date: 2016.01.01
    Time: 15:50:18
    6208 - Fuel Trim: Bank 1 (Add)
    P1136 00 [101] - System too Lean
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 70796 km
    Date: 2016.01.01
    Time: 15:46:54
    6212 - Fuel Trim: Bank 2 (Add)
    P1138 00 [101] - System too Lean
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 70796 km
    Date: 2016.01.01
    Time: 15:47:02
    The fuel pump was replaced by the previous owner. I'm thinking it might be a clogged fuel filter or maybe the pump is bad again? Anyone with experience with these codes, please chime in. I'm thinking of just replacing the fuel filter and pump.
    [2012 Audi S4 Prestige | S-tronic | Moonlight Blue | Black Nappa Leather | Sport Diff | Titanium Package]
    Jul 21 2004
    South Florida
    Its both banks so I'm guessing lpfp or fuel filter. Nothing new done to your car?
    Mike
    2018 Audi S5
    Gone-
    Mar 22 2012
    Northeast USA
    Thanks for the reply, Mike. The only thing that was done recently was the new clutch a little over 1k ago. Trying to find a DIY on how to replace the pump and filter is not going well....
    Also, I mentioned the CEL didn't come on. It finally came on when I hooked up the Vag-Com.
    Deactivated Two Rings
    Feb 07 2013
    Beautiful BC
    there was a recall for some fuel rails, had mine done.
    Nov 20 2014
    New York
    If it's the lpfp you looking to change PM me I replaced mine due to weird chirping and cricket like noises that it made at idle and it was also humming when I put my ear next to the tank but I never got a code for it. I just wanted to replace it preventively
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    P0089 is definitely lpfp related on the b7, ask me how I know. But I'm not sure P0087 is. I would guess hpfp instead, or something wrong with the fuel rail like said before. my car had recall done for the fuel rail before I owned it. It had a slight fuel smell when I bought it, so they redid that recall. Does this car have a pressure release valve on the rail?
    2021 Audi S4, P34 Intake
    Jul 21 2004
    South Florida
    Hey there. The B7 A4 platform actually had a crap hpfp. There were some aftermarket options eventually. Here are some early threads on it...
    http://www.audizine.com/forum/showth...-**Important**
    http://forums.vwvortex.com/showthrea...892&viewfull=1
    The reason I wasnt jumping on the hpfp hypothesis in this case is bc we have two hpfps and i'd guess if we had a hpfp issue it would more likely show up as a lean/demand issue on only one bank, not both. Can anyone double check my thinking on that?
    Mike
    2018 Audi S5
    Gone-
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by bhvrdr View Post
    Mike
    I'm well aware of the B7 2.0T fueling system. I ran a stage 1 hpfpupgrade and went through 3 lpfps, and changed about 7 followers.
    I was not aware that b8 platform had 2 hpfps however. That is interesting. It always seemed that the e85 upgrade kit from epl only offered one pump upgrade? Is that not the case?
    Jul 21 2004
    South Florida
    hehe, yeah the god awful fuel system on the B7. Man you had your share of difficulties with it. I thought the B7 was a pita with that stuff until I had to deal with the bad pistons on the B8 lol.
    You know I had just assumed there were two hpfp (one for each bank) like with the v8 fsi motors but I think you are absolutely right that they are only using 1 hpfp. In that case I guess we can throw that in the mix of possible issues too, lol.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    There is only one HPFP. It's the same one used in the 2.5 TFSI. HPFP is at the engine, and LPFP is at the tank.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Mar 22 2012
    Northeast USA
    You definitely bring up an interesting point about the hpfp. I do notice the car stumbling on itself when I give it more throttle. Slight throttle seems fine. Anything over 1/4 throttle seems to cause a stumble/misfire. And, the previous owner had the in tank fuel pump replaced at around 28k. I'm thinking I might have the car professional diagnosed before I start spending money on things I don't need.
    Mar 22 2012
    Northeast USA
    So, finally had the S4 fixed and it turned out to be the hpfp. For future reference if anyone comes across the P0087 code, check the hpfp.
    From what the tech said, the lpfp should be operating at about 4 bar and when the hpfp kicks in I was running at 5 bar. When the hpfp kicks in it should be 10 times that. After a week I can finally drive the S again.
    Aug 09 2011
    Brooklyn, NY
    did you ever get a p0089 code?
    I changed the lpfp in tank one already still having issues and the code.
    '16 Audi S6 4.0TT Eurocharged ECU - Current
    '12 Audi A6 3.0T Prestige - 187/57 DP Eurocharged ECU /TCU - Trade
    '06 Audi A6 3.2 Prestige - Sold
    '00 VW Jetta VR6 - Donated
    '98 Audi A4 Stage 3 - Gone
    Mar 22 2012
    Northeast USA
    Quote Originally Posted by SPONGE View Post
    when I had the hpfp issue it was only the P0089 code for my car. I would definitely investigate the hpfp next.
    Aug 09 2011
    Brooklyn, NY
    Quote Originally Posted by awwturbo View Post
    Thanks I'm changing out both sensors. If the problem persists, I'll change the HPFP and Cam Follower.
    Aug 09 2011
    Brooklyn, NY
    I have successfully defeated this code.
    I changed everything related to the fueling. Lol.
    I changed the two fuel sensors (fuel rail and next to pump.)
    In-tank fuel pump and filter
    HPFP
    Cam Follower
    Changed my thermostat while I was in there (to save on labor while I was in going to be in the area.)
    I believe the sensors should be changed. I changed everything for piece of mind and so that if the sensors didn't fix the issue I wouldn't have any more down time.
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    I also had this pop up but it disappeared after getting scanned. Any idea if it could've just been a phantom code?
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
