Results 1 to 13 of 13
    Jan 01 2016
    Beaver/Pennsylvania
    2.7 Cam Chain Replacement/ Cam Chain Tensioner
    Hey guys. Figured I'd ask, I'm going to be doing my timing belt and waterpump soon. My seals for the cam chain tensioners are leaking.. Should I get new tensioners and Chains too? Slight rattle at startup sometimes. 180,000 miles on her. Any input would be appreciated. Thanks
    Preventive maintenance is always easier and better than corrective maintenance.
    Using Tapatalk
    Aug 04 2009
    Glen Ellyn, IL
    While you're in there it's a good idea to check the pads, particularly the pads on the bottom of the tensioner. Also check the oil pickup screens to be sure they're no clogged. A little rattle on a cold start for a moment or two is deemed acceptable by Audi. If the tensioners were bad/not receiving oil pressure the rattle wouldn't go away. You can replace chains if you like, they do stretch a little bit over time, they're about 100 bucks a pair. But the tensioners shouldn't ever go bad under normal circumstances.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Id say a tensioner will fail sooner than the timing chains will. If you have the cash to get the oem parts, do it.
    Aug 04 2009
    Glen Ellyn, IL
    The chains don't fail but they stretch bringing timing with them. It's not enough to cause damage but it brings the engine out of peak efficiency. Tensioners are a bit pricey to fix what isn't broken anyway.
    @fourings | Build
    Veteran Member Three Rings JTown77's Avatar
    Feb 01 2010
    2002 S6 red, 2003 2.7 allroad stage II blue, 2005 4.2 allroad silver, 2003 FLHRCI
    Charlotte N.C.
    I am replacing the tensioner on bank 1, mine looks slightly different than this. Is this the correct diagram?
    I have a rosstech vcds HEX-USB+CAN Interface and cam lock bar to rent with deposit in the Charlotte area. Like all C5 owners I am looking for local parts!
    Aug 04 2009
    Glen Ellyn, IL
    I've done this sooo many times and my recommendation is to NOT count links, it's too confusing. ELSApro says to line up the notches with the cap arrows and it's never wrong.
    -Exhaust cam notch must be dead on the arrow since it's tied to the crank.
    -If your chains are old they'll be slightly stretched so count on the notch being turn just past the cam cap arrows. The notch will NEVER be before the arrow. If it is move the intake cam forward.
    -If it's more than a little bit past the arrow then look at the links critically and decide if the notch will be closer to the arrow but not before the arrow if it's as close as possible then you're good! No need to count.
    Procedure for later models including the 2.0T uses a measurement range to determine cam timing and there is tolerance. Timing is not necessarily a number of links, it's a distance. Trust the notches and arrows, not the links.
    @fourings | Build
    Senior Member Three Rings Arsenal2012's Avatar
    Aug 20 2015
    Chicago
    Quote Originally Posted by 4rings2turbos View Post
    Listen to him!
    We did mine not to long ago and instead of the counting method we lined up and I just finished a 2800mile trip with no issues.
    Aug 04 2009
    Glen Ellyn, IL
    Epic trip man, can't wait to get back to work and wrap it up.
    @fourings | Build
    Feb 01 2010
    Charlotte N.C.
    Thanks for the advice!
    Feb 01 2010
    Charlotte N.C.
    So I completed the new bank 1 cam chain tensioner, and the third slot block 91 reads adjustment OFF. What is going on? The engine runs fine and the fourth slot cam adjustment reads -.5 - 0. no CEL I do have a new noise in that bank almost like a hyd. lifter tapping in an old v8.
    Aug 04 2009
    Glen Ellyn, IL
    Were you careful to not tighten the tensioner compression tool too much? The tensioners can be damaged this way.
    @fourings | Build
    Nov 23 2018
    Long Island, NY
    Quote Originally Posted by JTown77 View Post
    I realize this thread is a couple of years old, but I have a question about setting up the cams, do you set them up with the appropriate chain roller distance, and notches matching to cap marks with the cam tensioner compressed with the cam tool or at their natural resting position (if such a thing exists)?
    I ask because when I replaced the tensioner seals to fix an oil leak onto the exhaust of my 2000 b5 I marked the chains/cam sprokets and thought I got them reinstalled correctly, but my engine now throws
    Code:
    16523 - Oxygen (Lambda) Sensor B1 S2
                P1579 - 35 - 10 Response too Slow
    This code indicates that B1 S2 is not detecting a lean condition (ie excess O2) in the exhaust.
    I think this could be because the intake cam is one tooth off.
    But when I re-opened the valve cover after locking the engine at TDC, the cam notches were dead on to the cap marks. However, when I compressed the tensioner with my hand, the intake cam was about one roller advanced from the mark.
    So my question is this: should the cam notches match the cap marks when the tensioner is compressed, or at it's natural rest position?
    thanks and happy Thanksgiving!
    Andy
