Results 1 to 12 of 12
    Veteran Member Three Rings Waspjr's Avatar
    Feb 03 2013
    Wifes jacked up f350 on 24's custom paint job landrover lr3
    Osoyoos/bc/canada
    Metal splash shield fab
    Thin aluminum splash shield i am building just going to run dzus fasteners
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Nice work!
    And I see that you are fabricating two NACA ducts.
    While you are at it why not go for three? Or four? there appears to be plenty of room.
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    why not just get a skid plate?
    Apr 15 2014
    Ottawa/Gatineau Canada
    Mine
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    ^Is that the Thor plate?
    "Beep beeeep bloop boop" - R2D2
    Feb 03 2013
    Osoyoos/bc/canada
    Nice work!
    Thanks i get bored at work on lunch breaks Yeah i was on the fence i like the ejection or ventury effect but whats your input on this for winter ? Should i make them removable
    Feb 03 2013
    Osoyoos/bc/canada
    Quote Originally Posted by Gberg888 View Post
    I like to build things and i have access to shears shrinkers expanders breaks and etc.
    so that and i have ADD
    Feb 03 2013
    Osoyoos/bc/canada
    Quote Originally Posted by Luxus Panzer View Post
    Mine
    Cool that should work nice
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Waspjr View Post
    I would put them in permanently. The thermostat will control the block temperature no matter what the outside temperature is and by having the ducts in place you can keep the underhood temperatures as low as possible.
    Apr 15 2014
    Quote Originally Posted by WiLl2FLY View Post
    Sure is. Paid for itself a dozen times over now ;)
    Jun 08 2008
    Calgary AB Canada
    I made a DIY for this with dimensions years ago if you search. :)
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Feb 03 2013
    Osoyoos/bc/canada
    Cool thanks everyone and i will put the ejectors in the oldguy
