Originally Posted by
old guy
The fans coming on at start up occurs when the ECM is getting conflicting information from the two sensors. It knows something is wrong but it doesn't know exactly what so it goes into a protection mode which includes applying full power to the thermostat heater as well as running the fans on high to provide maximum cooling to the engine.
Without being able to monitor the measuring blocks to see what is really going on all you can do is guess. It could be a faulty CTS or it could be because of a faulty thermostat. That is why I suggested unplugging the heater to the thermostat to see if it changes the block temperature. If the block heats up normally without the heater plugged in that would indicate a faulty CTS causing the problem. If the block temperature stays lower than normal that would indicate a faulty thermostat.
Edit: I should also mention that if you check for codes you will find one for the cooling system malfunction. Your engine will remain in this condition until the code is reset (fans on high at start up, full power to the thermostat heater).
Okay, Update:
I replaced, the coolant flange on the back of the head, it had a slight leak.
I replaced both coolant temp sensors, 2 pin and 4 pin.
I replaced the coolant expansion tank, the lid wasn't a good fit/warped.
I started the car up, no fans, it still took a while to warm up but MUCH quicker. I bleed air/steam 2-4 times then couldn't get anything but water to come out.
The hard pipe reach a temp of 196 degrees.
The return hose on the heater core reached 90 degrees, inlet still reaching 130-140 degrees.
When driving the car, the heat was warm, when slowing to a stop it would cool down.
I pulled the return hose off completely at one point, had my mate rev the engine and water came out the core, didn't explode, but ran out quick.
Why can't I get water to push through my heater core!
