Just had to pull out the engine on my b6 s4 due to the accessory plate power steering spline drive rounding out
The car also had cold and warm start rattle sometimes so I decided to replace all guides, tensioners and service the cam adjusters with the JHM bits.
While out I have also replaced the oil check valves and valley gasket as it is so easy to do at this stage.
I have followed the Audi workshop manual to the dot for re setting the timing with all the correct tools, and torqued bolts to proper settings but when I have finished and I rotate the engine to check that the cam tools fit back in I am about 1-2 degrees out?
I can not figure out why it is out?, am I missing something? or does this sometimes happen and I just need to do it again?
I have timed various engines over the years but never a V and now feel a bit lost
Anyway decided to walk away from it for a while as I feel like I am going nuts.
I will try again when the new cam bolts arrive but just thought I would ask to see if I am missing something stupid?
Thanks Andy
