Results 1 to 24 of 24
    Jan 22 2014
    Fairfield, Ca
    What the F@%k just happened?
    Hey guys, here's the quick story:
    I was trying to fix an oil leak that I thought was from the front main crank seal, when I got to it, it was dry as a bone. My entire underside of the oil pan is covered, so I replaced the pan gasket. Buttoned everything up and it had a horrible idle, loud and shaky like. I thought I might have messed up the timing, so everything came back appart. I did an inspection of the pistons via scope and they are damp, confirming timing. I verified TDC through the #1 cylinder and put her back together, turn the key and now it doesn't start at all, with the same nasty sound and vibrations while turning over. WTF happened here? I've taken this car apart a million times and never had a timing issue.
    Now small details that may or may not have anything to do with the issue:
    I pulled off the negative battery terminal prior to starting work. I normally don't always do this when working on the car, but since I was raising the motor and trans to replace the oil pan gasket I wanted to be safe. I thought this could be my issue (loss of tune memory or something, but I reflashed my tune and it acts the same.)
    I found a broken tranny mount while I was unbolting the transmission from the frame. I replaced it with 034's street mounts, this could be causing what I feel is excessive vibrations, since I have never felt my car idle with them installed.
    I couldn't get my pan to fully clear the subframe, so I pulled the oil pump to give me more clearance. The only thing this would have done had I messed it up would be prevent the engine from getting lubricated, that could give the engine a rougher idle, but I'm leaning more to the mounts.
    I replaced my forward oxygen sensor, this was to help with a readiness issue I am having. I thought I ordered the rear sensor which is what I believe is causing my problem (I'm still investigating if this was my fault or ECS). I'm 90% sure you don't have to do anything special when you replace these sensors, but even then it would idle right? (This is by far the easiest fix and will try swapping it back tomorrow).
    I'm working on this alone, so I can not verify spark on the valve cover, but I know the plugs were dry, but the piston was wet, so I'm leaning to spark is there, but at the wrong time (again with the timing issue).
    Lets hear your ideas, I'm so close to part this thing out after the last 4 days of cascading issues.
    2005.5 A4 Avant; TSI cam follower conversion. Build Thread
    99.5 1.8TQM; Maestro, GTX2867R, and a ton more mods. RIP
    Build Thread
    Aug 30 2014
    United States
    Are you drive by wire? Tried a throttle body adaptation?
    Apr 01 2011
    B5 on jack stands
    charlotte
    ^that or an intake leak of some kind.
    powered by
    Hot Boi parts
    Senior Member Two Rings CoyneJ's Avatar
    Dec 29 2015
    B5 S4
    Illinois
    i have electric throttle body and i encountered same issue after i disconnected my battery, rough idle and stalls but otherwise runs fine
    Apr 01 2011
    B5 on jack stands
    charlotte
    If you're drive by cable turn the ignition on with out turn\starting the engine to let the throttle body cycle. You'll hear it buzz ( throttle body) and let me know when you're tired of that gtx2867r..
    powered by
    Hot Boi parts
    Jan 22 2014
    Fairfield, Ca
    Quote Originally Posted by demonmk2 View Post
    Quote Originally Posted by Articus View Post
    DBC, but I could try a TBA.
    I know I will have to sell/part it out prior to me moving in the summer of 2017, this hiccup has me thinking of doing it earlier. Tomorrow is another day, we'll see what it brings.
    Build Thread
    Jan 22 2014
    Fairfield, Ca
    I did the TBA this morning and it started but ran like crap. After about 10 seconds I shut it down, misfires on all cylinders. I have a second mark on my timing belt cover that I made when I first got the car, the position where the dash on the crank was almost an inch off. I did the timing to the factory position (usually I mark where the dashes are and just line them back up) this last go around being that I verified TDC before bolting everything back together.
    I guess this could be one tooth off and still run without anything binding..... Back apart we go.
    Build Thread
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Quote Originally Posted by B5A4coastie View Post
    Maybe one of your sensors got messed up. When I got into my fender bender, I punctured my radiator and fluid was leaking causing a misfire. When everything got fixed with oem equipment it went away. I know this is a basic answer but usually the simple things are what we over look.
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Pull your valve cover and check you timing using the camshafts
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Jan 22 2014
    Fairfield, Ca
    Quote Originally Posted by Avant Nate View Post
    Help me remember, all valves closed on #1 at TDC? It's on the compression stroke right?
    Alright, here we go using the factory marks: (you can see my second mark to the right, that's where I have found it in the past)
    Spot on
    The valves are in fact closed.
    The Cam timing marks line up...
    Jan 22 2014
    Fairfield, Ca
    I have a compression tester in route and I'll check spark the same day.... Besides the cam position sensor, I'm not sure what else would need changed.
    Build Thread
    Feb 06 2013
    WV
    Your not going want to hear this but I had the exact same issue. It turned out being my maf which was brand spanking new. I have always wondered if the a8 maf get screwed up the maestro. The stock maf heats up after you turn the car off for about 5 seconds to clean the element. With the voltage clamped on the a8 maf they might not be getting cleaned or worse cooked. I changed to an old maf and the car ran fine. Now I remove the maf before working on the car.
    I know it sounds silly but if you an extra maf try it. Mine would still run but it ran like shit.
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    When you had misfires in all cyl, did you pull plugs to see if they were wet?
    Just an FYI, if you have excessive fluid in the cyl that cannot be burned off quick, you can bend a rod.
    Check your crank sensor connection. Pull, clean & reconnect. Did you disconnect all hoses when raising? Could have disconnected or torn.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Jan 22 2014
    Fairfield, Ca
    Quote Originally Posted by zandrew View Post
    My MAF sensor is also a few months old....
    Quote Originally Posted by viceprp View Post
    The first go around they were dry, now they are wet. I disconnected as little as possible when I raised everything. I was pretty careful but it's worth looking over everything.
    Build Thread
    Jun 30 2008
    Erie, Pennsylvania
    My brother was freaking out when he put his car back together after a timing belt and some other stuff. Wouldn't idle, ran super rough. He thought the worst. Then I put my finger over the vac port he left disconnected at the manifold and everything was fine. ;)
    Apr 01 2011
    B5 on jack stands
    charlotte
    When did you install the icm delete fsi conversion ?
    powered by
    Hot Boi parts
    Jan 22 2014
    Fairfield, Ca
    15K miles ago, I made sure everything was still tight. I'll be checking spark and compression today when my g/f gets home.
    Walkie, I would be so happy for it to be that simple. You are more than welcome to come down and finger my engine.
    I've been taking small steps lately, only spending an hour or two tops out there because (1) it's cold now and (2) so I don't get super frustrated.
    Build Thread
    Jan 22 2014
    Fairfield, Ca
    Are you sure AEB has a crank position sensor? I feel like that's something I would know it has.
    Edit: yep, should have googled this first.... I thought this was strictly a tachometer.
    Jan 22 2014
    Fairfield, Ca
    I found the reason it doesn't run, however I still don't know what caused it.
    Drum roll please..................
    Zero as in (0) compression in the #4 cylinder
    I'll continue the rest of this journey in my build thread.....
    Build Thread
    Oct 17 2009
    alonE, Pa
    You pull the head? Melted piston?
    STEVE
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    LOL, I just replaced a piston on a 2006 Chevy Colorado. First start up and the thing hardly idled and shook a ton. My mind was racing, but I kept cool and looked around. Plugged a massive vacuum line back in and the thing purred.
    unfortunately, doesn't sound like OP had the same luck
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jan 22 2014
    Fairfield, Ca
    I hope to pull the head today. The piston looks ok via scope.
    Build Thread
    Nov 03 2011
    All Over!
    Possibly a bent valve.
    One thing to note - it's not always a good idea to use the crank pulley marks as a timing reference. I have come across pulleys where there's been so much slop, the timing marks varied between 1 and 3 teeth on the timing belt. Worn sprocket keyway can make things worse.
    The most reliable timing reference is on the flywheel, via the "window" on the top left of the bellhousing.
    1986 Type 85 Audi 90 quattro
    Jan 22 2014
    Fairfield, Ca
    That'll do it. The piston has the smallest mark where they touched..... It didn't take much.
    Build Thread
