Results 1 to 24 of 24
Thread: ARP Main studs
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    ARP Main studs
    At what point do arp main studs become a necessity? Is there a certain hp/tq number where people recommend using them?
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    over 500. Honestly the stock ones are not that bad. You do have to buy brand new ones, they are one time use only.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    I think they'd be a worthwhile purchase if they're like 100$. I've reused my stock ones 4 or 5 times and I'm in the 500whp range. I'm more worried about an asteroid hitting my car. I don't think a hp limit is what should concern you. It should be if you will be pulling the head somewhat often.
    Jan 16 2006
    LA CA
    My ARP bolts have paid for themselves many times over in reuse.
    Jan 12 2014
    Fargo, ND
    I know the oem bolts are stretch bolts, I've also heard you need to align hone the main caps if switching to studs due to their torquing specs or something to that effect.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Wake me up when the big torque spec debate starts
    Kinda looks like the block breaks before the oem bolts, so I say the studs are pretty much pointless.
    This is usually a once and done thing. Not sure wtf people are doing to justify them based on being able to reuse.
    Oops, thought I was in the s4 section I dont know if this applies to you guys.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Dec 09 2015
    neither here nor there
    I haven't heard of anyone breaking a main bolt, like in any street car, EVER. Has anyone else?
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Quote Originally Posted by vrmm View Post
    Where have they ever been $100? Because all I see is $200+, so unless you plan on changing the head 10+ times...
    Aeb 204-4102
    06a 204-4104
    Both include tool
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Nov 14 2011
    NW
    I was saying that they would only be worth it to me if they were only 100$. I know they are more, hence me not having them.. I bought bosch 1000cc injectors for a bit more, you can buy a used hx35 for that much, a good ewg, about a billion things. Not just head bolts... Boring!
    Nov 16 2010
    WetSide, WA
    Main studs/head studs? Aw screw it, they'll figure it out
    Nov 14 2011
    NW
    Haha touche ;) I have my 500ish whp without any sort of aftermarket main stuff. I've never read about people needing them. So I suppose I worry about it as much as a t rex riding an asteroid hitting my car, which is to say not at all. I really like how 95% of the people in the thread(including myself) choose to see it how they wanted.. Or I just misled everyone with the first response
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Reused your stock head bolts 4 or 5 times? Maybe that's why you've had to pull your motor's head so many times...
    Anyway, some quick reading regarding the original topic:
    For a performance or heavy-duty application, the use of studs is preferred whenever possible instead of main cap bolts, in those instances where a choice is available. Studs provide the ability to obtain much more accurate torque values because the studs don’t twist during tightening as do bolts. Because the studs remain stationary during nut tightening, the studs stretch in one axis alone, providing much more even and accurate clamping forces. Also, because the use of studs results in less wear applied to the block’s threads, this extends the life of the threaded holes in the block over periods of servicing/rebuilding. This is especially important when dealing with alloy blocks. The use of studs also eases main cap installation, and contributes to main cap alignment. There is less chance of main cap walking because the studs remain stationary during cap clamping
    Reference: http://www.autoserviceprofessional.c...ving-proper-cl
    "You know you have a bad idea when Ford guys are making fun of you."
    Nov 14 2011
    NW
    Nahh revving too high, je pistons, and sky high egt's is why. Nothing to do with head bolts. Or main bolts.... :)
    Jan 12 2014
    Fargo, ND
    A dinosaur riding an asteroid, that made me lol. I'll be running almost the same setup as vrmm, HX35, built head and such. From what I'm seeing, it's more or less peace of mind.
    Jan 16 2006
    LA CA
    I went with ARP Main studs in my 1.8t block and then transferred them into my 2.0 block. $120 seemed like a reasonable cost to me. But I also put ARP on everything I could.
    http://www.performancebyie.com/arp-1...-06a-late-1-8t
    Edited to say I just found them now for 63$
    http://www.eurospecsport.com/product...e-updated.html
    EHK 198 901 06A/B 1.8L Turbo, 99-05 Golf/Jetta/New Beetle/Passat and Audi A4, 10 stud set $63.75
    Dec 09 2015
    Quote Originally Posted by Eurospecsport [/QUOTE
    EHK 198 901 06A/B1.8L Turbo, 99-05 Golf/Jetta/New Beetle/Passat and Audi A4, 10 stud set $63.75
    This is screwy, and contradictory. 06a didn't come along until 2001 model
    I don't see a listing for AEB/ATW. Are they the same ARP main studs as 06a?
    Jan 16 2006
    LA CA
    I would call them and ask all those questions.
    Dec 23 2009
    Boulder, CO
    Well everyone is selling the 204-5402 for cheaper. Which ARP says are for 1.6 and 2.0 blocks. What's the difference?
    Jan 12 2014
    Fargo, ND
    Should be noted, I'm AEB as well. Pretty sure the 06a is 10mm while the 058 is 11mm, could be mistaken though.
    Dec 09 2015
    Quote Originally Posted by Rodgman15 View Post
    You start a thread about main studs, but for some reason, you and everyone else is talking about head studs
    Jan 12 2014
    Fargo, ND
    Quote Originally Posted by Kronprinz View Post
    negative ghost rider, that's what I was told by a reputable company who will remain unnamed, but I didn't bother with anymore research until I heard from someone with a BT setup. Maybe i'm thinking about a head bolt conversation I had with someone at said company, but there's a size difference in main studs as well between the 2 blocks. I was, and still am talking about main cap studs.
    Here's a link to "early" 1.8t blocks
    http://www.performancebyie.com/arp-m...and-8v-engines
    Dec 09 2015
    Well according to techtonicstuning 058 main bolts are 15mm shorter than 06a main bolts
    http://techtonicstuning.com/main/ind...oducts_id=1968
    http://techtonicstuning.com/main/ind...oducts_id=1969
    Jan 12 2014
    Fargo, ND
    ECS shows the same thing for the stock bolts. Pretty sure length is different for studs as well.
    Dec 23 2009
    Boulder, CO
    Lolzn I was confused as well. Completely missed that point. First time I heard someone ask about main studs.
