Originally Posted by
plush
triple bump. Help!
If your tire is wearing unevenly then check your control arms. Just did my passat b5.5 and my wife's allroad uppers and quick and easy as long as the pinch bolt wants to play nice. I had torn bushings on both cars and outter and inner edges of my tires were gone.
In my experience the outter tie rod end vibrates (pretty violently if you're at highway speed) under braking if they're gone. I usually change about 6 tie rod ends a year and all of the boots on my tie rod have never been ripped. An easy assessment is to jack the car up like Glennda5id said and grab the wheel and try to move it left and right then up and down. You'll be able to feel and see the play in the outter tie rod right away.
My left outter cv joint on the passat is going and that causes a click when we're letting off the gas and then getting back on the gas pedal. It's my student driver car so the kids are pretty hard on gas/brake control. Rather than just replacing the outter cv joint with a kit, I got a quote from Raxles for $220 per axle and plan on replacing the entire axle.
Like Rollerton said, your problem definitely sounds like an inner cv joint. inners vibrates when load is applied to them. Have you done one before? They're not bad at all. I put a refurbished Chinese crap on my rear axle about 1.5 years ago and it's already vibrating again.
