Results 1 to 40 of 42
    Aug 09 2012
    2013 S4 phantom pearl
    IL
    biggest fear, is my reality :-(
    I finished my stage 3 build/tip to 6 swap. after getting everything back together, I filled all fluids and followed the initial startup procedure. after going to start it, I hear a click, almost like the starter tried, but is stuck. I can't say for sure that's it, but that's what it sounds like to me. I've double checked connections and am stumped. 034 did the ECU reprogram for manual using M box. I don't think that's it, but again, can't say for sure. any advice would be greatly appreciated. I really hope this project wasn't for not
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Quote Originally Posted by das4 View Post
    Remove the starter and have it checked. What are you afraid of exactly?
    Sent from my SGH-M919 using Tapatalk
    Sep 23 2007
    The starter may be in there at an angle and binding with the tone ring. try and adjust it before anything else.
    Aug 07 2014
    2020 Q8 Prestige,2023 S5 Prem+
    Stanwood, Wa.
    Dead battery??
    Aug 09 2012
    IL
    okay I'll give that a shot first. @royal769 sr: just have an uneasy feeling when it doesn't fire up after 5 weeks of work on it
    Aug 09 2012
    IL
    Quote Originally Posted by new2s5 View Post
    Dead battery??
    it's not a dead battery kind of click. volt meter on the dash reads 12-13 when I turn key to On
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    So pull the starter and check it to see if it works.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Aug 09 2012
    IL
    the ground strap for the starter is the cable on underside of passenger frame rail, correct?
    Veteran Member Three Rings sjmelling's Avatar
    Jan 06 2010
    Winchester -> Centreville, VA
    Yes, I ran into same issue on my first motor pull. Tightened up the ground and she fired right up. Good luck!
    Stephen J Melling
    2001.5 Audi S4
    ~~Laser Red Stage 3, Rods, F21's, other stuff and things
    2000 Audi S4
    ~~Hibiscus Red, Silver Interior, 01E, stock AF
    May 30 2015
    canada
    check yer grounds, had a similar issue
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    can you turn the motor over by hand aka with a breaker bar or torq wrench??
    2008 Ibis RS4....GETing tuned
    May 22 2013
    Las Vegas, NV
    Dude.. I know how you feel. Been paying insurance on a car that all I seem to do is pull the motor out and mess with things all the time
    May 22 2013
    Las Vegas, NV
    But mechanical stuff seems easier to fix then most electrical demons
    Aug 09 2012
    IL
    Quote Originally Posted by axnjaksn View Post
    yes I can
    Mar 07 2013
    yes I can
    well there ya go, that's a start of some good news. that would be my worst fear, hearing the clicking and the engine not turning over anymore.....probably just the starter....
    Aug 09 2012
    IL
    what's the best way to test a faulty starter
    - - - Updated - - -
    it's worth noting the starter worked just fine prior to the 6 speed swap
    Aug 09 2012
    IL
    FWIW, this isn't my video, but this is similar to what mine sounds like: http://youtu.be/9qVHp0VVUJs
    his gauges and everything turn off when he attempts to start but mine do not. everything stays illuminated on my car
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    You could bench test it by removing it and hooking it upto a 12 volt source. the housing of the starter itself is the ground.
    it would be hard to misalign the starter unless you have a fancy pants flywheel and the tone ring is all messed up.
    Like others said, id check grounds and the 2 wires on the starter itself again.
    Jul 25 2014
    MI
    If it helps any I had a seized alternator pulley which prevented my car from starting and acted similar to a dead battery. I Could turn engine without accessory belt on. Only way I found it was when I tried to get a new one and found I couldn't take pulley assembly off. So I tried using the car To hold alternator by putting it back on and managed to turn the pulley. Put everything back together and fired right up.
    2011 Audi S4
    2001.5 Audi S4 (awaiting rear differential)
    (Money + Parts + Time) X Knowledge = Healthy S4
    My b5 is a tortured soul struggling against the pavement in the pursuits of speed
    Aug 09 2012
    IL
    Quote Originally Posted by s9chelil View Post
    I was thinking maybe it was something preventing engine from turning, but when I turn the crank by hand, everything spins freely. I also took note of the writing on the accessory belt. when I attempt to start it doesn't budge which tells me the starter, or something, is preventing anything from turning. this HAS to be that starter. not looking forward to pulling stuff back out, but it comes with the territory on these cars
    Aug 09 2012
    IL
    Quote Originally Posted by rguil View Post
    nope, OEM flywheel. I'll check the wiring. maybe when I'm attempting to start, there's a loose connection and it jumps off contact? idk. I'll triple check and worst case, pull the starter
    Veteran Member Four Rings Yesmar's Avatar
    May 15 2009
    couple 2.7t's, and a tacoma
    Harrisburg, PA
    Are the tip and 6speed starters the same? Did you pull the starter and try it with jumper cable directly to the starter off the car?
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    That does seem like a starter or juice problem. Did you paint a bunch of shit and forget to leave a path to ground?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Aug 09 2012
    IL
    so, not anywhere near worth the stress I gave it last night. got it fired up. I only hand tightened the second, flatter starter nut. make sense that the starter would "pop" when i tried firing it. the current/spark was jumping the cable off of the post, losing power. tightened it up, and boom, reliable start every time. here's how she sits:
    looks a lot better in person. zilla: is it normal for my RPMs to sit here with a 034 93 octane tune?
    Nov 16 2010
    WetSide, WA
    No telling, it depends on how it was tuned.
    Prob around 800 when all warmed up usually so doesnt look crazy or anything.
    Turning up the idle might also help get around idle misfires.
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by zillarob View Post
    What he said. I did this to mine it helped smooth out the idle. I'm idling at 950. Easy to do in vcds
    Aug 09 2012
    IL
    so it's not under load, but it only revs up to about 5500 RPM. I do not have vag com, which I'm assuming I really need now that I'm stage 3 in this pig. any ideas of what the problem could be?
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Get it all together and take it for a drive before worrying further. Mine only revs to 4200 when under 3mph, but then it spits fire. ;-)
    Seriously though, it is probably just the tune keeping it at 5500. Best bet is to contact 034.
    Aug 09 2012
    IL
    Quote Originally Posted by DieselElectric View Post
    you da man. will do. rebuilding a CV joint tomorrow then throwing it all back and dropping it for a TD. thanks to everyone for the help along the way. couldn't have, at least correctly, done this build without the help and archives along the way. huge fan of the B5 and always will be
    Nov 16 2010
    WetSide, WA
    Cars with vss unplugged are limited to 5k. Not sure what mph enables the higher limiter in stock config.
    Aug 09 2012
    IL
    I believe that bigger is plugged in. I'll double check it. and the speedo works
    Jan 17 2015
    2001 Noggy S4
    toledo, OH
    Yay das4! I got about $800 saved for swap parts. Wish i was doing some turbo things too ;)
    Aug 09 2012
    IL
    Quote Originally Posted by incontrol7 View Post
    let me know if you need help along the way. I asked a ton of questions. not gonna lie, it's a biatch of a project, BUT definitely worth it if you set your mind to it, not horrendous. total time to get where I am was 5 weeks, but that includes a ton of tear down engine and rebuilding crap. and taking days off here and there. and working a full time career. these cars should've never been tip!
    Nov 16 2010
    WetSide, WA
    How fast were you moving when it had the 5k limit
    Aug 09 2012
    IL
    it wasn't down. i have it up and supported. I haven't rev'd in gear. and won't, not too comfortable with that. it was with gear in neutral that j hit the 5200-ish rpm limit
    Nov 16 2010
    WetSide, WA
    That would be it then.
    You can change those numbers around for a type of launch control.
    Aug 09 2012
    IL
    ah. they did program with launch control. that makes sense
    Aug 09 2012
    IL
    how do I turn launch control off? I actually don't need/want it really they just added it to my tune
    Nov 16 2010
    WetSide, WA
    There are a few different types of launch control so hard to say.
    All of them will require you to pull the file off the ecu, make changes, and flash it back.
    This can be from easy, to impossible depending on your tune.
    It only activates under certain conditions that you will prob never see unless you are trying to get it to activate.
    Easiest thing to do would be to find out which kind you have, and learn what those conditions are.
    This is info on the native style lc if interested.
    http://nefariousmotorsports.com/foru...ic=151.0title=
    Aug 09 2012
    IL
    as always, thanks.. reading through it
