Results 1 to 16 of 16
Thread: Dsg question
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Dsg question
    I just bought a one owner 2011 s4 with 39k miles in excellent condition, but have noticed a weird 2-1 shift when coming to a stop. It seems "harsh" in my opinion so I thought I'd ask if that's normal. Every other up/down shift is totally fine. This is in dynamic, but does it in comfort too (just a bit less since there's probably less line pressure). Also just read these trannies need to be serviced at 35k miles...true?
    Will
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    Dsg question
    DSG issue is normal. It makes some noise and 2-1 shift can be a little clunky in dynamic or manual mode at low speed/rpm. As for service, what does the service manual say? I don't have it on me at the moment.
    Dec 30 2015
    Sacramento, Ca
    Thanks for the quick reply brotha! Ahhhh ok good to hear it's normal to downshift like that. I was just browsing on here and came across a post about the service...ill check my manual and confirm.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by BlownOne View Post
    Will
    Yes, definitely get it serviced when due, 35k is the first DSG service interval. A little pricey at dealer, probably $ 600-800 total, but not sure how much of that is DSG. When I had it done I had Audicare.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    As stated normal and over time you adjust how you slow to a stop, atleast i have and it doesnt happen any more.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Dec 30 2015
    Sacramento, Ca
    Rodger that! I will do the service myself, but I'm sure oem fluid isnt going to be cheap lol
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by cspcrx View Post
    Hahaha I've already tried several different ways of stopping in an attempt to minimize it. Seems if you let it 2-1 downshift while still slightly rolling, it's not as bad.
    Jan 04 2013
    Phoenix, az
    Drove me crazy at first also. But over time seemed to find the sweet spot. Still get a hard shift every now and then but not like i did when i first got the car.
    Dec 30 2015
    Sacramento, Ca
    Yea it juts feels so harsh and it makes "California stops" tricky lol. Thanks for the input brotha!
    Established Member Two Rings LurkAllDay's Avatar
    May 27 2015
    Centreville, VA - MAIC
    Same issue with my 2012. Really annoyed me with DC traffic.
    So I did myself a favor and got the 034 Motorsport tranny mount insert. I'm not saying clunk is gone 100%, but it is most the time.
    https://store.034motorsport.com/tran...a5-s5-rs5.html
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by LurkAllDay View Post
    Yea I noticed the hard 2-1 on the way home from buying the car...told my girl something might be wrong with the tranny haha. I'm just glad that's normal for the twin clutch and thanks for the info on the insert...ill give it a shot!
    Mar 07 2015
    Central New Jersey
    Is shifting from 2nd gear to 1st gear bad on the tranny? I don't think it is but I could be wrong so id like to here everyone else's input
    Aug 03 2015
    Calgary
    I got the eurocode insert, practically the same thing, a bit cheaper. Anyway, it definitely reduces this clunk slightly. Maybe 70% better? Don't notice it in comfort mode at all with the insert, but feel it in manual mode sometimes for 2-1 shifts.
    2011 B8 S4 DSG Full ADS & Sport Diff - U2nelson CR-15 strut brace review - Eurocode intake - S5 rear sway bar review - Eurocode transmission insert
    2005 E46 M3
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    I think I downshifted into 1st by mistake when I first got my car. Vowed never to do it again because of how "harsh" it was on the transmission. The only time I ever shifted into 1st on my 6MT A4 was when I wanted to start rolling forward, like from a red light or something. I never downshifted from 2nd to 1st. I always went from 2nd to neutral. IMHO, 1st gear is used for starting out, not slowing/stopping. Even now in my DSG when I'm in manual mode and slowing to a stop, I'll downshift all the way to 2nd but won't go to 1st. The indicator on the dash doesn't change to M1 until the car is stopped.
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Time for the DSG Tune. Completely eliminates the clunk. Might as well add a Stage II while you're at it
    The only other thing you may notice (I did) upon test driving the S4 initially is that it idles a little rough. Normal though.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Three Rings Sean@APR's Avatar
    Feb 01 2013
    C7 S6
    Opelika, AL
    Quote Originally Posted by pdqgp View Post
    This.. we spent weeks testing scenarios to figure out exactly when it would clunk and precisely what combinations of speed/rpm/throttle/braking caused it and then worked each of them out one by one until we were clunk free.
    Even my S6 (Same transmission as a B8.5) did it with the factory calibration. I don't know why they tuned them that way.
