Results 1 to 20 of 20
    Mar 31 2014
    2013 Porsche Cayenne Turbo
    B8.5 B&O Speaker information?
    I can't find any information the speakers in the B&O system.
    Where are they located, who makes them, what size are they, what impedence, load, etc.
    Is that information not public?
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    Subb for information as well..
    But door speaker is faulty
    Mar 31 2014
    Quote Originally Posted by lowjonathan View Post
    Rear left speaker is faulty.
    Jul 16 2008
    Finland
    B8.5 speaker layout
    The B&O speakers are obviously made by Bang & Olufsen. The PR-code for the B&O system is 9VK, so look in the parts list for parts listed for PR-9VK.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Mar 31 2014
    Is there any info on size, etc, so that I can replace both rear speakers with nicer models?
    Jul 16 2008
    Finland
    Fronts are 8", rears are 6.5", but as I recall they're 8 Ohm so you need to watch the impedance.
    Aug 21 2012
    Pittsburgh
    Actually, if I remember correctly, the speakers are actually Panasonic drivers. The tuning of the system was performed by B&O.
    Nov 28 2015
    Montreal, QC
    is this covered by the extended warranty offere dby audi ?? my passenger front speaker ',rattle'' between 10-20 volumes. it's not a clear sound, there's something wrong with the speaker.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    read your warranty see what is covered and what is not in sound system. There are different levels of coverage
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Dec 21 2014
    FL, USA
    Quote Originally Posted by TDIaholic View Post
    All the speakers, except the subwoofer, are 4 Ohm; the sub is 8 Ohm.
    2021 SQ7, Prestige, Sport package, Luxury package
    2015 S5 DSG, ADS, Sport Differential [Sold]
    EPL Stage 2, EPL TCU, AWE ColdFront
    Jul 16 2008
    Finland
    Quote Originally Posted by LBosh View Post
    OK, thanks! I remembered wrong, I thought all the woofers were 8 Ohm.
    Jun 11 2011
    Is it safe to assume the amp can handle an efficient 4 ohm subwoofer then being the same amp driving all channels?
    Jun 30 2015
    What are options available to replace out front door 8" speaker?
    Is it necessary to put in component speaker?
    Or just normal 8" mid range speaker??
    Sent from my A0001 using Tapatalk
    Volk racing G25
    KW v3
    Hotchkis ARB
    034 adjustable upp arms
    034 tranmission inserts & mount
    Uprated front bushing.
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Custom tuned with DSG remap
    Senior Member Three Rings slacktide's Avatar
    Mar 01 2015
    Seattle WA
    The B&O speakers are made by an Italian company called Faital. http://www.faital.com/prodotti.php
    1993 Audi 90 Quattro 2.8 5MT - Sold with 245,000 miles on it.
    2002 Audi A4 Avant Quattro 3.0 6MT - Retired commuter, Dog Car, Costco runner, Snowmobile.
    2014 Audi S4 Quattro Sport Diff 6MT - Daily Driver. CR-15, Chipwerke, minor cosmetic mods. Eventually I'll get around to the audio build.
    Oct 09 2015
    Phoenix AZ
    Quote Originally Posted by slacktide View Post
    The speakers in the B&O sound systems (Audi A4 and A5 at least) are made by Faital. They are also no different than the speakers used in the base systems, except for the manufacturer. They all carry the same basic part number.
    As far as I know, Bang and Olufson does not make any speaker drivers. It took me a while to figure out just what B&O did bring to the systems besides the name brand on the speaker grilles. What they provide is acoustic mapping of the car interiors and software for the amplifiers.
    Sep 05 2012
    Not a ton of technical info but see http://www.bang-olufsen.com/en/car-a...of,-,fame,-,a4 (haha, they refer to the B8 as the "hall of fame" as they've put up the B9 page now)
    Veteran Member Three Rings S4Gibbs's Avatar
    Jul 26 2016
    VA
    I have managed to score a set of B&O speakers and amp for cheap. Although aftermarket is definitely the way to go for audiophiles, I think the B&O system is still a considerable upgrade over stock. Anybody who says the B&O system doesn't sound much better than stock is in denial or deaf!
    Does anybody have any info as far as differences between the stock and B&O wiring? Will the B&O speakers and amp drop and plug right in?
    Thanks in advance!
    Jun 29 2012
    Austin tx
    Quote Originally Posted by phanker View Post
    I would like to know this as well?
    Any help?
    JC
    Established Member Two Rings 1BadB6Avant's Avatar
    Nov 11 2016
    92 SLC Corrado_ Mk4 R32 _ 83 El Camino _13 Allroad
    Duarte Ca
    Quote Originally Posted by S4Gibbs View Post
    Thanks in advance!
    Did you find out if this was a plug and play setup.
    Jul 16 2018
    Atlanta
    It can't just drop in, there's 4 new speakers you have to wire up in the B&O over the standard. Take the front left corner. In the standard system, the dash corner tweeter and the door mid/bass are in parallel on a single amp channel. In the B&O system, the dash corner midrange and the door sail card tweeter (so you'll need a new sail card cover that has the tweeter hole as well, etc) are in parallel on a single amp channel, while the door midbass driver is on a dedicated amp channel. So it's not major work, but I wouldn't call it "plug and play" by any means.
