Results 1 to 21 of 21
    Oct 31 2015
    Florida
    S4 Bolt ons needing tune?
    So I have a manual 2016 S4 and I'm thinking about adding an intake and catback exhaust. If i install them would i need a tune? A buddy of mine put bolt ons on his 370z and needed a tune afterwards because it wasn't running right. Do the S4s run into this issue as well?
    Deactivated Three Rings
    Aug 24 2015
    No
    Sent from my iPad using Tap,Tap,Tapatalk
    Senior Member Three Rings chet's Avatar
    Nov 29 2012
    2011 Jetta Sportwagen TDI, 1984 Volvo 240 DL Wagon
    SF Bay Area
    Nope!
    2013 S4 Prestige / Revo Stage 1 / Milltek non-res / Stoptech ST60 380mm / H&R OE Sport / Alu Kreuz / 034 Control Arms
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    You will be spending money on sound and no added performance.
    That is sound from the exhaust, what ever it sounds like and maybe some supercharger whine.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Oct 31 2015
    Florida
    Ok cool just wanted to be sure before i start modding. I eventually will tune it.
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    The gains come from increasing the air flow through a boosted motor, more boost more horsepower.
    Understand there is the Black Night, Audi TD1, trumps all warranty on your boosted motor.
    2016 Z06/Z07 Vette
    Senior Member Three Rings phxS4's Avatar
    Oct 09 2013
    Phx/AZ
    Quote Originally Posted by QuickShift View Post
    Go stage 2 before you go bolt ons
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Intake and stage 2 and forget the exhaust, unless you really want the sound. For performance, that's all you really need for the most noticeable gains. And Stage 2 should cost you less or the same than exhaust, and give you like 60hp more than the exhaust.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Oct 31 2015
    Florida
    what does stage 2 consist of?
    Oct 09 2013
    Phx/AZ
    Pulley, belt, tune. You don't worry about TCU bc 6MT
    2013 S4 | Brilliant Black | DSG | Sport Diff | Fine Nappa | Carbon Atlas | B&O | Advanced Key | SC Badges | Roc Euro | AK | AWE catback | H&R OE l v810| GIAC Stage 2+
    Oct 31 2015
    Florida
    The problem with that is voiding warranty. The only thing my dealer is fine with is the intake and catback
    Oct 09 2013
    Phx/AZ
    I remember when I was worried about that once... I get the hesitation but I have gone back to my dealer flashed back to stock with the new pulley and belt...never questioned or TD1. Good luck and have fun with whatever you do... But in retrospect, Stage2 would have been the first thing for me.
    Sep 05 2012
    Many threads on this, but again: tune (or the TD1 flag, that comes from the computer detecting a tune) will not void your whole warranty. It will potentially (maybe even "probably") make them decline warranty claims that they believe are related - e.g. powertrain issues, on a case by case basis. It doesn't void your warranty for things like power locks or the radio not working.
    Officially an intake, exhaust or short-shifter can have the same effect. Someone had posted the official internal Audi document here a while ago. The computer can't detect these, but an evil/overzealous dealer tech can manually enter the flag. So your dealer might say they are ok with it, but in the rare case that you make a warranty claim and the regional rep (or whatever) looks at it when someone forgot to clean up all evidence of a mod, it "could" be an issue for you and the dealer.
    In real life, once you're sure your car isn't a lemon, just go for it and enjoy your car :)
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by phxS4 View Post
    ^^ this. At the very least you need to drive or ride in a Stage II to see. Just be prepared to go that route.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Nov 10 2014
    Apex, NC
    intake and exhaust on a 370z shouldn't cause any problems the ECU can compensate just fine.. my guess is whoever did the install on the exhaust messed up an 02 sensor
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    That's the dumbest thing I've ever heard
    2021 Audi S4, P34 Intake
    Nov 10 2014
    Apex, NC
    Why? I did .. Intake is the best performance adder which means Audi made the exhaust system very efficient .. You're picking up an extra 10-15 hp with the intake alone.. The single best compliment to the stage 2 system is a cooling system as once heat soak sets in then performance is affected. So if a person doesn't care for the slight bump in hp then going stage 2 first is the best bang for the buck .. Not really that dumb or maybe you don't hear a lot of dumb things often
    Sent from my iPhone8s using Tapatalk
    Present:
    Mar 21 2015
    I think stopping and suspension before that much more power.
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by doug97gxe View Post
    Not saying it's wrong to do it that way, but for some people, it really is about the sound. You don't need 450 hp in order to install exhaust and intake
    Nov 10 2014
    Apex, NC
    Oh ok gotcha
    Present:
    Dec 03 2008
    2018 SQ5
    I've always intended to get tuning, but did intake and exhaust right away to keep me happy for a while. It was just too quiet. Since my recent surprise $5k clutch debacle, I will be waiting much longer than intended till I have software. Luckily, the added acceleration and performance from this lwfw have made the car feel new again.
