Results 1 to 9 of 9
    Mar 29 2012
    SF
    JHM short shifter sits too far forward
    Or is this how it's supposed to be? My mechanic installed btw I did not. The trans is in neutral if u can believe it lol.
    Mar 29 2012
    SF
    Aside from it being a bit too far forward, I'm loving the quick smooth shifts. The knob is awesome too. Weighs a ton!
    Veteran Member Three Rings ktish's Avatar
    Nov 05 2012
    Yeah that looks pretty far forward. He probably has the adjustment on the base too far forward. If you're getting all the gears, the shift linkage adjustment should be all set. Its only a 6mm allen. You would just have to loosen that one 6mm allen and then slide the whole shifter base assembly back. ~10 mins max.
    Mar 29 2012
    SF
    *whew* I was worried it would always be like that. Thanks man!
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    JHM actually has some how to videos on YouTube that can help you adjust it if you want to.
    Gonzo
    Mar 29 2012
    SF
    I also find it strange that 1st gear seems to be moved to the right a small bit. What I mean by that is, when I would put the car in 1st gear I always move the shifter all the way left and then up. Now if I go all the way left, it blocks me from going up. I have to go up and go to the right a small amount. It's very odd feeling. It led me to mis-shift a few times. Does anyone know what I'm talking about or did that not make any sense.
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    Definitely check the jhm video, I installed this myself this weekend and the adjustment tutorial was spot on. Yours looks too far forward.
    2013 Phantom Black C7 S6 Stage 3 | 2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
    IG: tyscalzone
    Sep 17 2006
    Aurora, Colorado
    Quote Originally Posted by inked_up415 View Post
    It needs adjusting. Find the videos (there's two of them) and make the adjustments. Especially the second one since its for fine adjustments.
    Gonzo
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    If you have an android phone you can use clinometer to adjust the degrees the shifter is angled at. I'm sure iPhone has an app for it too.
