Wednesday,27,January,2016,18:52:08:41374-VCID:336548955194F6A6BC-5140,VCDS Version: Release 15.7.3 (x64),Data version: 20151216
8E0 909 518 F,,1.8L R4/5VT G 0001,
,Group A:,'091,,,,Group B:,'020,,,,Group C:,'002
,,Engine Speed,Engine Load,Adjustment,Adjustment,,Timing Retardation,Timing Retardation,Timing Retardation,Timing Retardation,,Engine Speed,Engine Load,Injection Timing,Mass Air Flow
,TIME,(G28),,Status,Bank 1,TIME,Cylinder 1,Cylinder 2,Cylinder 3,Cylinder 4,TIME,(G28),,,(G70)
Marker,STAMP, /min, %,,°KW,STAMP,°KW,°KW,°KW,°KW,STAMP, /min, %, ms, g/s
,0.34,1760,37.6,ON,21.0,0.00,0.0,0.0,0.0,0.0,0.17, 1720,37.6,4.76,12.33
,0.87,1840,36.1,ON,21.0,0.51,0.0,0.0,0.0,0.0,0.69, 1800,36.1,4.42,12.19
,1.38,1880,35.3,ON,21.0,1.04,0.0,0.0,0.0,0.0,1.21, 1880,36.1,4.42,12.94
,1.89,1960,35.3,ON,21.0,1.55,0.0,0.0,0.0,0.0,1.72, 1920,35.3,4.08,12.94
,2.40,2040,54.9,ON,21.0,2.06,0.0,0.0,0.0,0.0,2.23, 1960,34.6,4.08,12.81
,2.91,2200,78.9,OFF,0.0,2.58,0.0,0.0,0.0,0.8,2.75, 2120,77.4,10.20,34.14
,3.42,2440,98.5,OFF,-1.0,3.08,0.0,0.0,0.0,0.8,3.25,2360,89.5,11.90,45.3 3
,3.92,2720,132.3,OFF,-1.0,3.59,0.0,0.0,0.0,0.8,3.75,2640,116.5,16.66,66. 03
,4.44,3120,169.2,OFF,0.0,4.09,0.0,0.0,0.0,0.8,4.26 ,3000,160.9,24.48,94.17
,4.94,3560,168.4,OFF,-1.0,4.61,0.0,0.0,0.0,0.0,4.78,3440,172.2,26.52,111 .67
,5.45,4000,163.9,OFF,-1.0,5.11,0.0,0.0,0.0,0.0,5.28,3880,164.7,24.82,120 .53
,5.95,4440,164.7,OFF,-1.0,5.62,0.0,0.0,0.0,0.0,5.78,4280,164.7,25.16,133 .72
,6.47,4840,164.7,OFF,-1.0,6.12,0.0,0.0,0.0,0.0,6.30,4720,163.9,25.16,147 .39
,6.97,5240,160.2,OFF,-1.0,6.64,0.0,0.0,0.0,0.0,6.81,5120,162.4,24.48,158 .78
,7.48,5560,151.9,OFF,1.0,7.14,0.0,0.0,0.0,0.0,7.31 ,5440,155.6,23.80,157.31
,7.99,5880,144.4,OFF,1.0,7.65,0.0,0.0,0.0,0.0,7.83 ,5800,147.4,22.44,159.64
,8.50,6120,139.1,OFF,0.0,8.16,0.0,0.0,0.0,0.0,8.33 ,6040,139.1,21.76,159.14
,9.00,5520,13.5,OFF,1.0,8.67,0.0,0.0,0.0,0.0,8.84, 5840,20.3,2.72,2.22
,9.47,4040,41.4,OFF,-1.0,9.15,0.0,0.0,0.0,0.0,9.31,4560,14.3,2.38,10.86
,9.97,4040,44.4,OFF,-1.0,9.63,0.0,0.0,0.0,0.0,9.80,4040,43.6,5.10,34.64
,10.46,4000,36.1,ON,5.0,10.14,0.0,0.0,0.0,0.0,10.3 0,4040,36.1,4.08,26.92
,10.92,3960,26.3,ON,21.0,10.62,0.0,0.0,0.0,0.0,10. 77,4000,30.8,3.40,20.97
,11.41,3920,24.1,OFF,1.0,11.08,0.0,0.0,0.0,0.0,11. 23,3920,22.6,2.72,16.75
,11.91,3840,23.3,OFF,-1.0,11.58,0.0,0.0,0.0,0.0,11.75,3840,23.3,2.72,16. 83
,71.27,1960,26.3,OFF,-1.0,71.44,0.0,0.0,0.0,0.0,71.09,1920,25.6,3.06,9.6 9
,71.78,1960,28.6,OFF,-1.0,71.95,0.0,0.0,0.0,0.0,71.61,1920,27.8,3.40,10. 47
,72.29,1960,28.6,ON,6.0,72.46,0.0,0.0,0.0,0.0,72.1 2,1960,28.6,3.40,10.67
,72.81,1960,28.6,ON,21.0,72.98,0.0,0.0,0.0,0.0,72. 63,1960,27.8,3.74,10.75
,73.31,2000,28.6,ON,21.0,73.48,0.0,0.0,0.0,0.0,73. 14,1960,28.6,3.74,10.83
,73.82,2000,28.6,ON,21.0,73.99,0.0,0.0,0.0,0.0,73. 65,2000,28.6,3.74,11.08
,74.32,2040,28.6,ON,21.0,74.49,0.0,0.0,0.0,0.0,74. 15,2000,28.6,3.40,10.81
,74.84,2040,28.6,ON,21.0,75.01,0.0,0.0,0.0,0.0,74. 67,2040,28.6,3.40,11.14
,75.34,2040,28.6,ON,21.0,75.51,0.0,0.0,0.0,0.0,75. 18,2040,28.6,3.40,11.17
,75.85,2040,28.6,ON,20.0,76.02,0.0,0.0,0.0,0.0,75. 68,2040,28.6,3.40,11.25
,76.38,2080,29.3,ON,21.0,76.55,0.0,0.0,0.0,0.0,76. 21,2080,28.6,3.74,11.50
,76.89,2120,48.9,ON,21.0,77.06,0.0,0.0,0.0,0.0,76. 72,2120,39.8,5.78,21.19
,77.40,2280,80.5,OFF,4.0,77.57,0.0,0.0,0.0,0.0,77. 23,2200,75.2,9.86,35.42
,77.92,2520,101.5,OFF,0.0,78.10,0.0,0.0,0.0,0.0,77 .74,2400,93.2,12.58,48.75
,78.43,2880,144.4,OFF,0.0,78.59,0.0,0.0,0.0,0.0,78 .27,2760,125.6,18.02,74.72
,78.93,3240,171.4,OFF,-1.0,79.10,0.0,0.0,0.0,0.0,78.76,3080,164.7,24.82,1 00.72
,79.43,3680,168.4,OFF,-1.0,79.60,0.0,0.0,0.0,0.0,79.26,3560,171.4,26.52,1 13.92
,79.95,4120,163.2,OFF,-1.0,80.13,0.0,0.0,0.0,0.0,79.78,3960,165.4,24.82,1 22.58
,80.45,4520,165.4,OFF,-1.0,80.62,0.0,0.0,0.0,0.0,80.29,4400,166.9,25.50,1 38.75
,80.96,4960,163.9,OFF,-1.0,81.13,0.0,0.0,0.0,0.0,80.79,4840,164.7,24.48,1 52.08
,81.47,5360,157.9,OFF,-1.0,81.64,0.0,0.0,0.0,0.0,81.29,5240,160.9,23.80,1 59.39
,81.98,5680,150.4,OFF,0.0,82.15,0.0,0.0,0.0,0.0,81 .81,5600,153.4,22.44,162.44
,82.48,6000,141.4,OFF,1.0,82.65,0.0,0.0,0.0,0.0,82 .32,5920,142.9,21.08,160.92
,82.99,6280,135.3,OFF,1.0,83.16,0.0,0.0,0.0,0.0,82 .82,6200,136.8,21.08,156.61
,83.50,6240,53.4,OFF,1.0,83.67,0.0,0.0,0.0,0.0,83. 33,6440,132.3,21.42,160.17
,84.01,5280,15.0,OFF,1.0,84.18,0.0,0.0,0.0,0.0,83. 84,5600,14.3,2.38,11.00
,84.53,4360,121.1,OFF,-1.0,84.69,0.0,0.0,0.0,0.0,84.36,4360,88.7,11.90,91 .97
,85.03,4560,172.2,OFF,-1.0,85.20,0.0,0.0,0.0,0.0,84.85,4480,164.7,25.50,1 48.19
,85.53,4720,171.4,OFF,-1.0,85.70,0.0,0.0,0.0,0.0,85.37,4680,170.7,26.86,1 53.17
,86.04,4880,166.9,OFF,-1.0,86.21,0.0,0.0,0.0,0.0,85.87,4840,168.4,29.24,1 54.58
,86.54,5080,156.4,OFF,-2.0,86.71,0.0,0.0,0.0,0.0,86.38,5000,165.4,31.96,1 57.94
,87.06,5200,136.8,OFF,-1.0,87.23,0.0,0.0,0.0,0.0,86.89,5160,136.8,24.48,1 36.64
,87.58,5360,154.9,OFF,0.0,87.75,0.0,0.0,0.0,0.0,87 .40,5320,152.6,23.80,158.78
,88.09,5520,143.6,OFF,0.0,88.26,0.0,0.0,0.0,0.0,87 .92,5480,149.6,25.84,153.56
,88.61,5640,130.1,OFF,0.0,88.78,0.0,0.0,0.0,0.0,88 .44,5600,130.8,20.74,138.47
,89.12,5760,142.9,OFF,1.0,89.29,0.0,0.0,0.0,0.0,88 .95,5720,140.6,21.76,157.58
,89.62,5880,138.3,OFF,1.0,89.79,0.0,0.0,0.0,0.0,89 .45,5840,139.8,21.76,156.08
,90.13,6000,132.3,OFF,1.0,90.31,0.0,0.0,0.0,0.0,89 .96,5960,133.1,20.40,150.83
,90.64,6080,109.8,OFF,1.0,90.81,0.0,0.0,0.0,0.0,90 .48,6080,130.1,19.04,150.83
,91.15,5240,14.3,OFF,0.0,91.32,0.0,0.0,0.0,0.0,90. 98,5480,13.5,2.04,9.00
,91.66,4120,29.3,OFF,-1.0,91.82,0.0,0.0,0.0,0.0,91.50,4800,13.5,1.70,11. 22
,92.17,3480,24.8,OFF,-1.0,92.34,0.0,0.0,0.0,0.0,91.99,3440,41.4,4.08,28. 53
,92.67,3440,14.3,OFF,-1.0,92.84,0.0,0.0,0.0,0.0,92.51,3440,17.3,2.04,8.6 1
but maybe this one is easier to read
(time) (rpm) (cam (C.F) (knock cyl 1-4)(injection (g/s)
on/off) timing)
,0.34,1760,ON,21.0,0.00,0.0,0.0,0.0,0.0,4.76,12.33
,0.87,1840,ON,21.0,0.51,0.0,0.0,0.0,0.0,4.42,12.19
,1.38,1880,ON,21.0,1.04,0.0,0.0,0.0,0.0,4.42,12.94
,1.89,1960,ON,21.0,1.55,0.0,0.0,0.0,0.0,4.08,12.94
,2.40,2040,ON,21.0,2.06,0.0,0.0,0.0,0.0,4.08,12.81
,2.91,2200,OFF,0.0,2.58,0.0,0.0,0.0,0.8,10.20,34.1 4
,3.42,2440,OFF,-1.0,3.08,0.0,0.0,0.0,0.8,11.90,45.33
,3.92,2720,OFF,-1.0,3.59,0.0,0.0,0.0,0.8,16.66,66.03
,4.44,3120,OFF,0.0,4.09,0.0,0.0,0.0,0.8,24.48,94.1 7
,4.94,3560,OFF,-1.0,4.61,0.0,0.0,0.0,0.0,26.52,111.67
,5.45,4000,OFF,-1.0,5.11,0.0,0.0,0.0,0.0,24.82,120.53
,5.95,4440,OFF,-1.0,5.62,0.0,0.0,0.0,0.0,25.16,133.72
,6.47,4840,OFF,-1.0,6.12,0.0,0.0,0.0,0.0,25.16,147.39
,6.97,5240,OFF,-1.0,6.64,0.0,0.0,0.0,0.0,24.48,158.78
,7.48,5560,OFF,1.0,7.14,0.0,0.0,0.0,0.0,23.80,157. 31
,7.99,5880,OFF,1.0,7.65,0.0,0.0,0.0,0.0,22.44,159. 64
,8.50,6120,OFF,0.0,8.16,0.0,0.0,0.0,0.0,21.76,159. 14
,9.00,5520,OFF,1.0,8.67,0.0,0.0,0.0,0.0,2.72,2.22
,9.47,4040,OFF,-1.0,9.15,0.0,0.0,0.0,0.0,2.38,10.86
,9.97,4040,OFF,-1.0,9.63,0.0,0.0,0.0,0.0,5.10,34.64
,10.46,4000,ON,5.0,10.14,0.0,0.0,0.0,0.0,4.08,26.9 2
,10.92,3960,ON,21.0,10.62,0.0,0.0,0.0,0.0,3.40,20. 97
,11.41,3920,OFF,1.0,11.08,0.0,0.0,0.0,0.0,2.72,16. 75
,11.91,3840,OFF,-1.0,11.58,0.0,0.0,0.0,0.0,2.72,16.83
,71.27,1960,OFF,-1.0,71.44,0.0,0.0,0.0,0.0,3.06,9.69
,71.78,1960,OFF,-1.0,71.95,0.0,0.0,0.0,0.0,3.40,10.47
,72.29,1960,ON,6.0,72.46,0.0,0.0,0.0,0.0,3.40,10.6 7
,72.81,1960,ON,21.0,72.98,0.0,0.0,0.0,0.0,3.74,10. 75
,73.31,2000,ON,21.0,73.48,0.0,0.0,0.0,0.0,3.74,10. 83
,73.82,2000,ON,21.0,73.99,0.0,0.0,0.0,0.0,3.74,11. 08
,74.32,2040,ON,21.0,74.49,0.0,0.0,0.0,0.0,3.40,10. 81
,74.84,2040,ON,21.0,75.01,0.0,0.0,0.0,0.0,3.40,11. 14
,75.34,2040,ON,21.0,75.51,0.0,0.0,0.0,0.0,3.40,11. 17
,75.85,2040,ON,20.0,76.02,0.0,0.0,0.0,0.0,3.40,11. 25
,76.38,2080,ON,21.0,76.55,0.0,0.0,0.0,0.0,3.74,11. 50
,76.89,2120,ON,21.0,77.06,0.0,0.0,0.0,0.0,5.78,21. 19
,77.40,2280,OFF,4.0,77.57,0.0,0.0,0.0,0.0,9.86,35. 42
,77.92,2520,OFF,0.0,78.10,0.0,0.0,0.0,0.0,12.58,48 .75
,78.43,2880,OFF,0.0,78.59,0.0,0.0,0.0,0.0,18.02,74 .72
,78.93,3240,OFF,-1.0,79.10,0.0,0.0,0.0,0.0,24.82,100.72
,79.43,3680,OFF,-1.0,79.60,0.0,0.0,0.0,0.0,26.52,113.92
,79.95,4120,OFF,-1.0,80.13,0.0,0.0,0.0,0.0,24.82,122.58
,80.45,4520,OFF,-1.0,80.62,0.0,0.0,0.0,0.0,25.50,138.75
,80.96,4960,OFF,-1.0,81.13,0.0,0.0,0.0,0.0,24.48,152.08
,81.47,5360,OFF,-1.0,81.64,0.0,0.0,0.0,0.0,23.80,159.39
,81.98,5680,OFF,0.0,82.15,0.0,0.0,0.0,0.0,22.44,16 2.44
,82.48,6000,OFF,1.0,82.65,0.0,0.0,0.0,0.0,21.08,16 0.92
,82.99,6280,OFF,1.0,83.16,0.0,0.0,0.0,0.0,21.08,15 6.61
,83.50,6240,OFF,1.0,83.67,0.0,0.0,0.0,0.0,21.42,16 0.17
,84.01,5280,OFF,1.0,84.18,0.0,0.0,0.0,0.0,2.38,11. 00
,84.53,4360,OFF,-1.0,84.69,0.0,0.0,0.0,0.0,11.90,91.97
,85.03,4560,OFF,-1.0,85.20,0.0,0.0,0.0,0.0,25.50,148.19
,85.53,4720,OFF,-1.0,85.70,0.0,0.0,0.0,0.0,26.86,153.17
,86.04,4880,OFF,-1.0,86.21,0.0,0.0,0.0,0.0,29.24,154.58
,86.54,5080,OFF,-2.0,86.71,0.0,0.0,0.0,0.0,31.96,157.94
,87.06,5200,OFF,-1.0,87.23,0.0,0.0,0.0,0.0,24.48,136.64
,87.58,5360,OFF,0.0,87.75,0.0,0.0,0.0,0.0,23.80,15 8.78
,88.09,5520,OFF,0.0,88.26,0.0,0.0,0.0,0.0,25.84,15 3.56
,88.61,5640,OFF,0.0,88.78,0.0,0.0,0.0,0.0,20.74,13 8.47
,89.12,5760,OFF,1.0,89.29,0.0,0.0,0.0,0.0,21.76,15 7.58
,89.62,5880,OFF,1.0,89.79,0.0,0.0,0.0,0.0,21.76,15 6.08
,90.13,6000,OFF,1.0,90.31,0.0,0.0,0.0,0.0,20.40,15 0.83
,90.64,6080,OFF,1.0,90.81,0.0,0.0,0.0,0.0,19.04,15 0.83
,91.15,5240,OFF,0.0,91.32,0.0,0.0,0.0,0.0,2.04,9.0 0
,91.66,4120,OFF,-1.0,91.82,0.0,0.0,0.0,0.0,1.70,11.22
,92.17,3480,OFF,-1.0,92.34,0.0,0.0,0.0,0.0,4.08,28.53
,92.67,3440,OFF,-1.0,92.84,0.0,0.0,0.0,0.0,2.04,8.61
sorry I took long. I took even longer trying to make this easily readable.
