I can't say to the C7 platform, but in general it's all the same. I had a catless setup on my Mustang, and ran catless for a number of years on my old S4.
Sadly, the smell will never go away but you most likely will never notice it when your windows are up. However, you will notice it anytime you get out of the car, and whenever you have to roll your window down you will get the teary eye and the longer you sit the worse it will get.
I plan on shilling out the extra money for downpipes with high flow cats. You might be able to pickup a used catless setup and add HJS cats. I may be losing a little performance, but I've dealt with the smell for years and I'll pass on it.
The gains will always be better than stock, but as far as how much it's hard to tell as there haven't been a lot of reviews with just them. It also depends on cell count and their position in relation to the engine. Normally it is preferred to have them near the rear of the downpipe, but with the turbo placement on our cars it's not really known whether this is a factor anymore. Catless will always net the biggest gains, but you will have to give some concessions.
Yes, and yes. If you have a tune, odds are you will pass. The way the OBD setup is, as long as you don't have any CELs all that happens is they plug you in, and two minutes later you are on your way.
