Results 1 to 9 of 9
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    quick question timing related
    Does anyone know if the center boomerang shaped tensioner/guide come with a seal on the back. I just did my timing all over again and realized there was a seal on my old piece. Anybody have a part number for the seal
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Mar 31 2014
    KY
    green gasket does NOT come preinstalled on new components.
    It is part #179 109 139 A
    JHM kit comes with a new one. But dont forget the one on the back of the other tensioner. That one doesn't come in the JHM kit and you need to grab the old one and transfer it over.
    Nov 11 2008
    Thank you sir
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    sorry for the threadjack, but did you guys replace the a/c shaft seal that's included in the kit, I'm about to close the covers
    Mar 31 2014
    KY
    Quote Originally Posted by jakeoboy67 View Post
    I don't think I did. I think the JHM kit comes with the oil shaft seal? Although this guy said it was something for power steering... Not sure.
    http://www.audizine.com/forum/showth...1#post10630416
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    I didn't replace it either I don't think
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by badger. View Post
    I searched the OEM part number on the seal (079103051E) , and the parts diagram showed it was for the upper accessory drive (a/c shaft)
    the power steering seal calls for another part number (079103051J), although they look very similar
    Mar 31 2014
    KY
    good to know!
