So to start off this is not my first manual car, but I think most find these cars are different from dodges, and jeeps and other manual cars.
The two problems that I had with this car are the infamous throttle lag when you first get on the pedal, and that the revs seem to hang when you shift, most notably from 1st to 2nd.
Although I don't really have a solution for the throttle lag, I found a way (through the search button imagine that!) To deal with the rev hang. How I normally drove was to let off the gas and press the clutch in pretty much at the same time. I found some forums talking about how this is what causes the rev hang and that extra second for the rpms to get to where you need them. The solution?
Well what I found from my searching is that if you left off the gas completly and then push in the clutch it stops this. It's nothing drastic, as long as you are completly off the gas before you push in the clutch it supposedly stops the rev hang. So I thought yeah right but I'll try it.
It works! And I can't seem to shift fast enough now! There is no jerkiness like I thought there would be and now all I need to do is shift faster.
Just thought that I would share this with anyone that has the same issue that I had and is looking for a solution. Hopefully this helps at least one person on here.
