Results 1 to 19 of 19
    Sep 08 2015
    Connecticut
    35K Service & 6MT Trans Fluid Question
    Hey everyone,
    My car is in right now for the 35K service. I have supplied plenty of Motul 8100 Excess for the oil change, and have dropped it off overnight in order for the transmission fluid to be cold in preparation to flush it.
    I was told when I dropped it off, that it is not "necessary" in terms of routine maintenance to flush this fluid, but I have also read great things regarding shift feel when this is done every 30/40k miles.
    I have been reading that the OEM fluid is pretty pricy, and would like to avoid having to tack on another few hundred dollars to this service if i really dont need to flush it. At the same time, I do not mind paying a bit more if it will maintain my transmission. This is no longer my daily driver, and I would like to keep it as pristine as possible.
    Any input? Should I give the okay to flush? Is it worth the extra $ when thinking about longevity and performance? Any input appreciated
    2012 S4 6MT Monsoon/Titanium/Prestige - 30% Wincos Ceramic tint - otherwise stock for now
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Manual transmissions do not require a fluid change, at least not below 100,000miles, you are being lied to, look in your manual for the 35k mile service you will see no mention of this. I think it's only vw/a3 haldex systems that require a fluid change every 35k miles and that's not a transmission fluid change.
    Sep 08 2015
    Connecticut
    To be clear, I was the one who suggested flushing the fluid per some conversation I have had on this board. The dealership looked at me funny and essentially said that if I really want it done, they can do it although it will be somewhat pricey.
    I am only still kicking this around because I have heard improved shifter feel is noticible after it is flushed. Along with seeing some before and after pictures of old fluid, I still dont see this hurting the car in the long run at all.
    Any one else have any input?
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Ive done it at 30k.. Shifts were crisp and smooth after.
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Senior Member Two Rings roadawg's Avatar
    Jan 09 2015
    I had my trans fluid flushed at 50K. It is not necessary as per Audi's maintenance schedule, but after flushing the fluid the car shifts smoother, most notably when it is cold. The 1 > 2 shift when the car is cold is worlds better.
    I don't think its a bad idea, and should make a noticeable difference.
    2012 S4 - Man pedal, sport diff, APR tune, Meisterwerk SS, AWE Exhaust & other goodies.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by Jkysh View Post
    You're not going to hurt anything and upgrading the fluid should make shifts smoother. That said, I wouldn't let the dealer do it, especially if they told you it's going to be expensive. It basically consists of draining the old fluid and refilling with an oil pump. Should take less than an hour for any competent mechanic. I've completed many MT fluid changes in a bunch of different cars over the year and upgrading to a better fluid almost always yields better shifting.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Nov 06 2015
    NY/RI
    What fluid is everyone swapping to? I just bought my s with 60k on it and am in the process of trying to determine if it needs a clutch or not...figured fluid would be a good place to start.
    Think I'm trying to pick between the two motul offerings.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I'm partial to Redline. I've used it for years and had very good results.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    I've heard that redline has some issues during winter in cold climates. I flushed mine at 96,000 miles recently and used Fuchs (rmeuropean). The old fluid wasn't horrible, but after doing the trans and diff, the slight whine I was hearing at low load is completely gone. Also, have had no issues with shifting in freezing temps lately.
    Both the trans and diff are easy. If you can turn an allen wrench and work a fluid hand pump, you can do this.
    http://www.audizine.com/forum/showth...1#post11251726
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Nov 06 2015
    NY/RI
    Not a fan of redline personally, used to run it in saabs years ago that had issues keeping gearboxes together but thats it. I run amsoil in my evo track car and my s2000. I went with motul engine oil since its on the approved by audi list, don't know how strict they are on gear oil for warranty stuff?
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Quote Originally Posted by blbroo View Post
    I just ordered some motul gear 300 since it is so ridiculously difficult to get my shifter into reverse when its cold. I mean use all of my strength to barely have it to push down with the redline
    Nov 06 2015
    NY/RI
    Yeah that's also part of the issues I have but on oem fluid (I assume) I just can't really find anything to help me decide between gear 300 and motylgear.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I've had fantastic results with redline down to -20F.
    Senior Member Three Rings draekin13's Avatar
    Jul 14 2014
    08 GTI, 11 F-350 King Ranch
    Kennewick, Wa
    I just did the 35k and my independent Audi shop didn't mention trans fluid flush, however he also knows that come spring I will be upgrading to stage 2 clutch so that may be why he didn't bother.
    2011 R8 v8 Manual Ice Silver
    2019 S4 Prestige Glacier White, Black Optics, S Sport
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by Vogz View Post
    I can't recall the brand, but I also had some issues in cold weather with aftermarket fluid in my b7 6mt. It was a bitch to shift in the cold. If I were to do it again, I'd go OEM.
    OP, I did my fluids at 100k, and even then, it wasn't even recommended.
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    I've heard of issues with Redline too. I'll likely use OEM at 100k mi.
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
    Stage 2 Banner Advertiser Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    How much oil did you guys buy for your trans flush? I'm having problems finding any capacity information. Is it the same as the A4?
    Mar 21 2015
    Quote Originally Posted by jbullin2 View Post
    http://www.audizine.com/forum/showth...605955-DSG-DIY
    Dec 21 2014
    Milwaukee
    Oops forgot to mention I'm 6MT.
    Sent from my VS986 using Tapatalk
    AKA: jbullin2
