Results 1 to 25 of 25
    Active Member Three Rings auditrackspeed's Avatar
    Jun 17 2014
    Went over gas station raised plate , now oil pan leaking
    Yesterday went to royal farms to get air , i had no way of getting around the things that stick up out of the ground , i heard a scrape . Now my oil pan is leaking very bad to the point where it can not be driven . I checked it out its leaking from the front of the pan at the mating point . Some input would be nice if you think its bent or cracked possibly . Thanks
    May 30 2015
    canada
    damn how low are you? make sure the upper sump the pan attaches to isn't cracked
    Jun 17 2014
    not too low , nothing crazy . How could i tell if that is cracked ?
    Feb 27 2011
    Winnipeg
    those cast pans don't bend, they crack/break/shatter, hope and pray you did not muck up the upper pan cause they're a bit of a bitch to change, I'd just pull the motor to repair that, lower pan is easy to change and only $60 for a new one.
    Try and get some pics so we can see
    Aug 24 2014
    Newport Beach, CA
    It's most likely just the lower pan that's cracked and leaking, it takes surprisingly little effort to break those unfortunately.
    2024 M3 Comp xDrive
    Jun 17 2014
    Quote Originally Posted by christianb5s4 View Post
    The post above yours is saying pull my engine ?
    Feb 21 2012
    MB S55 - (607hp/671tq), Suzuki GSXR 1000
    Chico/CA
    Lower oil pan is cracked, I did the same thing going over a speed bump when i first got my car. don't pull your motor.
    2000 Laser Red Stage III+
    Veteran Member Three Rings goalieman24's Avatar
    Mar 29 2011
    Quote Originally Posted by auditrackspeed View Post
    Post above was talking about the upper pan.
    Jun 14 2007
    2000 S4
    Connecticut
    Yes - he said if your upper was damaged as well.
    If it is just the lower pan then that's not a big deal to order and replace. You'll obviously have to order: new lower pan, sealant, and oil for an oil change.
    Jul 28 2014
    Denver
    Sorry to hear about that! I scrape all the time and freak out every time I do.
    hey, quick question...do you have the plastic skid plate on?
    if you do and it still cracked the pan, i think i'm going to get either the Thor or Panzer skid plate.
    I'm noob here (1st post) and have had my B5 since 7/14. really like the info and the discussions here.
    Jun 17 2014
    I just ordered a new pan hopefully thats all it is .
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Damn. I drove over a parking block before in my 97 1.8t. I scraped the heater off the pan and got the car stuck. It sucks that so little ruined your pan.
    Sent from my Jailbroken iPhone 6s 9.0.2 using Tapatalk
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Sep 23 2007
    Just jack the car up and check it?
    Jun 17 2014
    Quote Originally Posted by jturnbull View Post
    i did its leaking from around where it mates to the engine
    Jun 17 2014
    Im looking at oil pans it says 2.8L passat oil pans are the same as 2.7t pans .
    Feb 27 2011
    Winnipeg
    Yes lowers are the same, just have to make sure its from a newer 2.8 with level sensor hole
    Jul 04 2012
    Woodbridge, VA
    I can honestly say I don't miss being slammed... Reluctant to even do drop at all for reasons like this...
    Veteran Member Three Rings Audimilo's Avatar
    Apr 19 2014
    CO
    Replace lower pan, use Permetex Anerobic to seal it, get a panzer plate for future protection.
    i've hit so much shit (mostly snow debris etc) with my panzer... best 250 i spent on the car....
    Jun 17 2014
    Quote Originally Posted by Audimilo View Post
    thank you
    Aug 06 2008
    Canadia
    I got a thor skid plate (not saying mine is better than the other ones, i honestly couldnt tell you) and its probably saved my ass 3 times since i installed it 2 months ago. Definitely worth the investment. But its too low for me, im going to raise the car up a bit.
    Jun 17 2014
    Okay its not the pan, the car is only leaking when the car is running as well , its leaking right where snub most bolts to the engine
    Jun 17 2014
    Theres not even a scrape on the oil pan or anything under the car what could this be ?
    Mar 12 2015
    A coincidence? Possible that it was leaking before you scraped. Snub mount bolts to the upper oil pan so if you're sure that's where it's leaking from...
    Btw, did you notice that whoever bought your imola is now trying to turn around and sell it for $10.5K
    Jun 17 2014
    Quote Originally Posted by Schtug View Post
    No it was not leaking before . There car is not driveable now or i will run out of oil . Yes i seen he is selling the imola for 10k and he states car is 100k miles when it has 152k
    Mar 12 2015
    Take the snub mount bracket off and see if the upper pan somehow cracked behind it? This is a strange one for sure. There's only so many places on the front of these motors for oil to leak from. If it's spewing bad enough that you're scared to drive it then it shouldn't be impossible to find.
    He just rounded the mileage down, some people man, I swear. Lol
