Results 1 to 11 of 11
    Mar 10 2015
    Massachusetts
    Left low beam not working.
    Hi all, I have been researching and thinking about this for some time now. My left headlight low beam is not working. I replaced the bulb obviousl. After that didn't work I have been researching and researching to find some solution with no prevail. They are Halogen lights, i have found a lot on the xenon ballasts. Are there any fuse, relay, or control modules that would cause one low beam to go out. My next thought would be the wiring and connections. Can i replace individual connectors and wires without buying a whole headlight wiring harness? At this point any help would be much appreciated. Thanks
    May 20 2014
    e92
    My guess is harness. If you can figure out which wire is the issue you can change that single wire (unless its broken somewhere near the control module that is inside the car). There is not much in halogen headlight wiring. Just two wires that goes to the bulb. One ground, one 12V. Test it out.
    Mar 10 2015
    Massachusetts
    Quote Originally Posted by trj View Post
    Thanks, Is the control module under the dash drivers side behind the fuse panel like the b6?
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    Mine was doing the same thing when I first bought the car; it eventually got to where the foglights weren't working either. Everything I read said that the Control Module was bad. Come to find out, one of the plugs on the CCM was partially unplugged and had started working itself out; once I plugged it back in, everything worked perfectly and I haven't had an issue yet.
    May 20 2014
    e92
    Quote Originally Posted by Ross08 View Post
    Yes. Exact same as in a B6.
    Mar 10 2015
    Massachusetts
    Quote Originally Posted by drmonkey View Post
    one of the plugs on your power control module in the engine bay? Doesn't the power control module regulate the power going to the headlights?
    Sep 04 2015
    Clear Lake, TX
    No, under the steering column. The Comfort Control Module.
    Feb 24 2004
    Minneapolis
    Almost. Comfort and convenience is in the trunk and controls interior lighting, power locks, alarm. The one under the steering column is the right one but it's the Central Electric Module.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Sep 04 2015
    Clear Lake, TX
    Quote Originally Posted by mtroxel View Post
    Ah, got them confused. All I know is for some reason one of the plugs was partially unplugged and causing my headlight issues.
    Oct 24 2015
    Perth, WA
    Mate, do you have a photo of exactly where this is. I have been looking for the alarm module for ages. All of the threads here where it is shown diagrammatically haven't helped. There is nothing where the amp is either :(
    My respray thread
    Feb 24 2004
    Minneapolis
    Hmmmmmmm....now I'm the one who's wrong. I forgot they moved the CC Module up under the driver's seat in the B6 & B7's. B5's were in the trunk. Here's Bentley's picture:
