Results 1 to 31 of 31
    Oct 19 2008
    Brooklyn
    4.2 engine part out
    I bought a b6 s4 to do a 2.7 swap the v8 took a hit and cracked the oil pan everything for the engine is for sale shoot me offers on what you need
    SOLD LIST
    Intake manifold
    Valve covers
    Rear engine cover over oil filter
    Oct 19 2008
    Brooklyn
    Bump all available harness ecm, intake manifold, radiators
    Active Member One Ring Scottish Burro's Avatar
    Dec 17 2014
    '04 Tahoe Z71
    Maryland, USA
    Do you have the rear engine cover? Coil pack wiring harnesses in good shape? Thanks
    Junior Member One Ring
    May 29 2008
    Impala SS, Sierra 2500HD,
    Rothesay, NB
    How much shipped for intake manifold 04619 and does the flapper move freely? Pics? Thanks
    Oct 19 2008
    Brooklyn
    Intake manifold $200 shipped
    Flap moves freely
    Oct 19 2008
    Brooklyn
    Quote Originally Posted by Scottish Burro View Post
    The plastic cover with the audi emblem or the timeing chain cover? The plug release tabs are broken on the coil pack harness
    Sent from my SM-N920V using Tapatalk
    Oct 19 2008
    Brooklyn
    Everything still available
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    how much for the heads?
    Oct 19 2008
    Brooklyn
    Quote Originally Posted by q_dubz View Post
    Someone has dibs on the heads I need to pull them off and check them first too
    Dec 17 2014
    '04 Tahoe Z71
    Maryland, USA
    Hi, the plastic cover at the top rear of the engine that covers the Oil filter, etc. It does have the Audi symbol in it.
    If you have it, I'll take it for a reasonable price. can you pm or post a picture of it? Thanks!
    Oct 19 2008
    Brooklyn
    PM sent
    Oct 19 2008
    Brooklyn
    Have the airbox,maf,all radiators, ecm, throttle body
    Jan 16 2016
    Oshkosh
    Pm price on cam adjuster pass side
    Established Member Two Rings Durk's Avatar
    Oct 12 2015
    Pittsburgh
    Do you have the bolts that hold the coil harness to the valve cover?
    2005 Silver S4 B6 TIP
    Senior Member Two Rings rjpiselli's Avatar
    Feb 25 2015
    Pa
    There is a harness that plugs into the passenger side fuel injectors and two of the knock sensors.
    I don't care if its cut or what, as long as the wiring to the knock sensors is still firmly in the plug. price shipped to 17728?
    edit: I don't know how far back this harness goes or what else it's apart of. I do know that at least the fuel injectors on the passenger side and 2 knock sensors are attached to it.
    Current Audis: [B9 Q5 2.0T] - [B8.5 A4 2.0T]
    Previous Audis: [B8.5 Q5 2.0T] - [B8.5 Allroad 2.0T] - [Q3 2.0T] - [B6 S4 4.2] - [B5 A4 Avant 2.8] - [C6 Allroad 2.7T] - [C7 A6 3.2] - [B5 A4 1.8T] - [C6 A6 2.8] - [B5 A4 2.8] - [C2 200]
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Still have the alternator?
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Oct 19 2008
    Brooklyn
    I will check on the harness tonight.
    Yes still have the alternator
    Veteran Member Four Rings evildsmr's Avatar
    Sep 13 2012
    04 Imola V8, '21 Army Green Taco
    Denver
    How about the AC compressor?
    Established Member Two Rings Agent Anger's Avatar
    Mar 20 2011
    Long Beach Ca
    Still have the coil packs?
    Oct 19 2008
    Brooklyn
    $50 for compressor , still have the coils shoot a offer
    Feb 18 2014
    Arizona
    do you have a mechanical cam adjuster in good condition? if so, can you take a picture of the pinhole?
    and the front lower center grille?
    Oct 19 2008
    Brooklyn
    Quote Originally Posted by 2004B6S4 View Post
    Front lower grill? , I will check them out
    Feb 18 2014
    Arizona
    Quote Originally Posted by eddiedellz View Post
    this one - https://www.ecstuning.com/Audi-B6_S4--V8/ES7048/
    Oct 19 2008
    Brooklyn
    Sprry Was just parting the engine out not the car
    Oct 04 2013
    203 Connecticut
    If other guy didn't grab up the airbox let me know. I need. Thanks.
    Oct 19 2008
    Brooklyn
    Airbox or compressor?
    Jun 10 2016
    Pleasant Grove Utah
    still have cam adjusters?
    Junior Member Two Rings S4_Avant's Avatar
    Dec 11 2015
    2005.5 S4 ; 2017 Q7 3.0T
    Houston, TX
    Do you have the front engine cover ( 4.2 - v8 )?
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    SAI and kombi valves?
    Junior Member Two Rings slvrultrasport's Avatar
    Mar 15 2017
    4M Q7
    Summerville, SC
    Quote Originally Posted by Terry.Reese View Post
    I have a full set of combi valves hoses and pump. PM me
    Sent from my SM-G955U using Audizine mobile app
    B9 S5 FBO Stage 2+ ECU, Stage 2 TCU, 034 x34 intake with SuperDuper turbo inlet, CAP catless downpipe, CTS FMIC and charge pipes. Lowered on ABT HAS, variant Forged Evo Maxim 20x10 ET28.
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by slvrultrasport View Post
    That was almost 2 years ago. I have had a new engine since then. Thanks though.
    Sent from my XT1650 using Audizine mobile app
