Results 1 to 11 of 11
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    air filter replacement, OEM or AM
    I've read a post about K&N's filters causing issues with extra oil on them from the manufacturer. Also it lets more dirt in the engine? Its the first I've heard of this, and I've put K&N's on numerous cars in the past with out issues. Should I stick with OEM? By just looking at it, looks a bit restrictive. Another user said rinse the K&N with warm water and let it air dry for 2 days to get the grease out. I'm planning on a major maintenance project soon, and wanting to get some advice on filter choices. More grunt from the intake induction noise will be a positive with the AM filter choices over OEM. The power gains seems to be negligible.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    The issue with K&N filters is that people who run them tend to clean them WAY too often and flood them with oil afterwards... I've ran them for years without issue.
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    I have also ran them for many years with no issues. I have about 235k miles on my K&N in my B7. I always remove the filter from the plastic, shake it out and keep dropping/bouncing it on a newspaper until I can see no oil coming off and then let it sit out for a few hours. Most issues are all from user error.
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    Yup K&N FTW! 4 years strong! no issues!
    Veteran Member Three Rings Avus RS4's Avatar
    Apr 09 2015
    Niwot, Colorado
    I currently have the AEM filter, similar to the K&N but no oil to apply.
    I also ordered the spray cleaner as it's reusable and again, does not require oil to work
    Here's the AEM Air Filter:
    http://www.aemintakes.com/search/pro...?prod=28-20209
    Here's the cleaner:
    http://www.aemintakes.com/search/pro...px?prod=1-1000
    2007 Avus Silver Rs4
    Bone Stock
    Sep 27 2011
    Tomatoes
    Eastern PA
    K&N. I've run them in every car I've ever owned. Hundreds of thousands of miles with no issues.
    Suzuka Gray 2015 S3 Thread
    Misano Red 2003 RS6 Thread
    IG: @Flying_Tomatoes
    Oct 12 2008
    NW Washington
    OEM, just like my blinkers.
    All those pleats mean more surface area then any after market. I hope that's the right pic?
    But it's what you like, so there is no wrong choice.
    Jan 17 2015
    Portland, OR
    Thanks for the input guys, really appreciate it and feel much better going AM filters. Did you guys feel or hear any difference with the k&n or AEM?
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    Do it!!!! No issues.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by dufferdude View Post
    The pleats also serve the purpose of smoothing out turbulent air for proper metering.
    FRRG AZ Ring
    Apr 09 2015
    Niwot, Colorado
    Quote Originally Posted by AvusPdx View Post
    I went from stock OEM to AEM and it really woke my car up.
    Of course it was a combination of new plugs, fuel filter as well, but it drove nice soon after that.
    Bone Stock
