Results 1 to 7 of 7
    Established Member Two Rings timeattack's Avatar
    Jun 24 2011
    la rioja (españa)
    ECS clutch kit stage 1
    I intend to mount this kit audi a4 b6 my garrett gtx2863r 1.8t.
    alguin with this clutch kit could tell me if it works well?
    there is a problem with this clutch kit?
    some kind of noticeable improvement in acceleration?
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    I run that clutch and it does the job well, it is an OEM part after all (stock b5 S4 Luk clutch). The lightweight flywheel does chatter some (mainly with the AC on), but a lot of folks have successfully reduce it but also installing a Fluidampr crank pulley. With the LWFW the engine revs up and down noticeably quicker. I don’t have the logs in front of me, but on my stg2+ car I saw a reduction in FATs times (comparing 3500rpm-6500rpm time stamps while logging).
    If I had to do it all over again however, I would opt for the JHM clutch kit. It uses a B7 RS4 clutch, and a 9lbs flywheel vs ECS’ 11lbs.
    2019 SQ5 Prestige
    Oct 02 2006
    Wadsworth,OH
    You may be testing the limits on a Stage 1 kit with the S4 clutch. It really depends on what kind of power you plan on making with the gtx2863r
    I might suggest the Stage 2 with the RS4 clutch.
    Jason
    Jun 24 2011
    la rioja (españa)
    I like the Kit 1 ecs tuning stage . brings a problem to the gearbox ? marches come better or is more difficult to shift gears ?
    Dec 25 2004
    Earth
    I run JHM's clutch....and to date its the only clutch of that has held and lasted. I have had 5 different clutchs in my B6! 5!
    https://jhmotorsports.com/shop/catal...h=21_62_64_112
    The interesting thing...it utilizes the 'stock' B7 RS4 pressure plate and disk! STOCK!
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Three Rings VAGlover's Avatar
    Sep 23 2013
    b6 a4 track rat
    boston
    I run a spec stage 2 clutch. All I have is a stage 2 file with some bolt ons.
    I've launched it probably 100x and it's still holding quite well, it's also been to the drag strip a few times of that means anything as far as durability. It uses a 17lb steel wheel which is considerably more quiet than the ecs stage 1 lot's 12lb aluminum fw.
    Also my ecs stage 1 kit pressure plate broke a couple fingers leaving me with an interesting 200 mile ride home last winter. Though the failure may have been more due to driver error. Launching awd isn't the easiest thing at first.
    Ngpracing sells the SPEC kit i believe.
    Sent from my VS985 4G using Tapatalk
    Jun 24 2011
    la rioja (españa)
    front-wheel drive my Audi , I do departures from standstill and with only 320 horsepower and a torque approx 420/450 is not necessary Stage 2 clutch. While I try lol box changes.
