Results 1 to 12 of 12
    Feb 12 2015
    Ohio
    Coolant or oil splashing onto turbo manifold
    When the engine is cold, I get a rough idle and a bad misfire for about 20 seconds. After the 20 seconds, everything smooths out. I noticed on startup, I can see some fluid hitting the turbo manifold and burning off. It only does this once, it does not continually spray. I'm thinking(but hoping im wrong) theres a crack on the engine somewhere, or hopefully a bad gasket somewhere. I'm new to the 1.8t and would prefer not to take the turbo off if I don't have to.. Does anyone know what might be above this spot? Or better yet, any pictures?
    In this picture, there is no moisture. Just the spot in question. Photo credit to a4mods.com
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Unfortunately that sounds like the head or head gasket is leaking coolant into the combustion chamber then migrating out the turbo gasket. This is also likely the misfire until the coolant is burned out of the combustion chamber.
    Established Member Two Rings Shortrun's Avatar
    Dec 21 2015
    Ontario
    Put a white cloth under where it is dripping and catch a few drops. Shut down the engine before it all burns up.
    You really want to know what is dripping.
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Head issue had the same issue.
    Sent from my LGL33L using Tapatalk
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Veteran Member Three Rings Waspjr's Avatar
    Feb 03 2013
    Wifes jacked up f350 on 24's custom paint job landrover lr3
    Osoyoos/bc/canada
    Taste it is it sweet or not? And if your not a 100% on a headgasket use a headgasket sniffer kit it will never lie.
    Feb 03 2013
    Osoyoos/bc/canada
    I shouldn't say never but you know what i mean.
    Feb 12 2015
    Ohio
    Slight update. Here are the spark plugs I pulled. Spark plug 1 being the cylinder closest to the firewall. Spark plug 4 is the cylinder closest to the front end. You can see that spark plug 1 and 2(which are actually cylinder 3 and 4) have a coat of oil on the threads. Valve cover gasket? Not sure if this is related to the leak that I'm getting on the turbo manifold. I cannot find any signs of coolant or oil mixing/contamination.
    Apr 07 2011
    Yea, looks like it could be a headgasket problem. You could do a compression check.
    Compression Check
    Engine oil temperature at least 30°C
    Battery voltage at least 12.7 V
    Remove engine cover
    Switch off ignition
    Disconnect coil pack harness'
    Pull out ignition coils
    Remove spark plugs
    Disconnect connectors from all injectors
    Fully open throttle valve
    Check compression with the compression tester
    Using the compression tester-Operate starter until tester shows no further pressure increase
    Max difference between cylinders-43.51 psi
    You can rent a compression tester from Auto Zone/Advanced Auto. You have to put like a $50 deposit to take the tool but when you bring it back they give you all of your money back. Basically free but they want to make sure you don't keep the tool, if you do keep it, they keep the deposit.
    Jun 08 2008
    Calgary AB Canada
    Shine a flashlight down into the cylinder bore through the spark plug holes. Are any of the cylinders noticeably cleaner than the others?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Feb 12 2015
    Ohio
    Quote Originally Posted by onceover View Post
    I'm not able to get a good picture of them but from what I can see, cylinder 4(closest to firewall) looks very clean in comparison. This is a definite head gasket symptom, right?
    Apr 07 2011
    Yepp. Do a compression check.
    Jan 06 2009
    Sounds like coolant however if you suspect it is oil I wouldn't drive it till it's fixed. If it is oil, and if the slow drip becomes a fast drip or worse, there is a high risk of an engine fire...
    B6 2.7t BEL tuned by Bische
    B7 2.0t
