Results 1 to 2 of 2
    Established Member Two Rings btvm92's Avatar
    May 25 2015
    2003 Audi S8 Exclusive Edition
    Jonesboro, AR
    Warning Lights After Changing Brake Bulb
    I just got 3 warning lights today after replacing a blown brake light bulb. I've replaced bulbs before on headlights and turn signals and had no issues but after replacing this one I got warning lights on the dash that will not go away.
    The ESP I believe and the ABS lights are now both on, as well as the "Brake Light" warning in the LCD DIS, it also beeps at me constantly. It also looks like the "Brake Light Malfunction" light is on in the DIS.
    I hooked up my scanner and scanned brake electronics and no codes. Has anyone had this problem or is there something wrong with my ABS?
    Sep 17 2014
    Utah
    re-check bulb contacts, or replace new bulbs from different vendor again. i had the same issue with bulb from amazon, bought new ones from oreilly and all warning lights went away, it could be a combination of the those issues.
