Results 1 to 17 of 17
    Jan 15 2010
    Santa Barbara, CA
    Is anyone running 18's?
    I'm trying to make the car as comfortable as possible, since we have a new little girl that just joined our family. The TTX Ohlins helped a lot, but the 19's still cause some minor discomfort on rougher roads. I started tossing around the idea of switching to an 18-inch wider wheel, so I can drop the 10mm MTM spacers, get a more compliant ride, and probably get better handling in general.
    Has anyone done this? Are there fitment issues with the large brakes? I'd probably look at HRE's or other high-quality single piece forged wheels that look close to the OEM 19 (which I love aesthetically).
    Oct 22 2013
    Bicycles
    United States
    Quote Originally Posted by forbiddenbeat View Post
    I am running 18x9 Breyton wheels with 275/35 18s
    They look like these
    The setup is definitely more compliant and a lot grippier. The circumference is a little smaller though so the speedo is off a bit.
    Sent from my Oneplus 2 using Tapatalk
    Jan 15 2010
    Santa Barbara, CA
    Great, thanks for the input. So you'd recommend going 18 then, yes?
    This car is running 18's too - frankly it's hard to notice they aren't 19's with the meatier tires. I'd probably go 9.5 as well:
    http://s1056.photobucket.com/user/pr...7a63d.jpg.html
    I really like the HRE 301M. Expensive, but seems like it would look pretty good in a satin finish with our car: http://www.hrewheels.com/wheels/classic-series/301m
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    This has been done in the past. When I was researching wheels for my B6 S4 with RS4 front brakes and 330 mm rear brakes, I found this thread to be really helpful.
    http://www.audizine.com/forum/showth...ht=inch+wheels
    I ended up getting Advan TC3 wheels (had to get them redrilled to 5x112). They will clear any Brembo or StopTech RS4 front or rear BBK too. Once I wear out the 265/35/18 tires then I am going to get 275/35/18's just like SkyDude.
    Veteran Member Four Rings Chuuey's Avatar
    Mar 06 2010
    E36
    Yeah, there is a good conversation on this as Jimmy has linked.
    There are a few options for the RS. I went with fifteen52 turbomacs 18x9 et30. They clear all around without spacers.
    1998 E36 M345 T | 2017 B9 Allroad | 2002 996 GT2
    Previous:
    2001.5 B5 S4 Avant
    2009 B8 S4 6MT
    2008 B7 RS4
    1991 200 20v Avant
    2010 997 C2
    1988 E28 535is Dinan Turbo (RIP)
    2019 B9 A4
    Senior Member Three Rings torquesteer's Avatar
    Mar 02 2012
    RS4 & RSV4
    Currently on Hartmann GS 18s with spacers (for the winter):
    http://shop.achtuning.com/Hartmann-E...eels-Audi.aspx
    - Quan
    Jan 15 2010
    Santa Barbara, CA
    Thanks guys. Since HRE's are custom, I'm assuming I'll be able to get any offset I want. Do you guys know the ideal offset for a flush look on 9.5 inch wheels (equivalent to OEM + 10mm spacers, which is what I run now)?
    Apr 03 2010
    Northern Virginia
    http://www.willtheyfit.com/index.php...et2=25#content
    It looks like 18x9.5 ET 25 will keep the outer edge of the rim as close to what you have currently (OEM + 10mm spacers) as possible.
    Just to keep things simple since I didn't know what tire size that you were using, I used the stock 255/35/19 and then 255/40/18 to keep things easy on that website.
    Jan 15 2010
    Santa Barbara, CA
    Quote Originally Posted by JimmyBones View Post
    Awesome, thanks. I was thinking of running 275's, but maybe I'll just go 255 or 265.
    I actually just realized koolade's car above (the white one) is running 10.5in wheels, et30, with a 265/35-18 tire. I'll PM him since I don't see how he fit that in there. :)
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    I think koolade has rolled front fenders.
    Volk TE37SL in 18x10 +30 is an option, but you will need to redrill to 5x112 or run wobble bolts.
    If you don't mind a custom manufacturing lead time of 6+ weeks, Forgestar and CCW have several options that will clear our brakes. Forgestar's are also very fairly priced.
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    Quote Originally Posted by Chuuey View Post
    We have these and our Tarmacs in 18x9.5 or in 19x9.5 and we can do custom offsets.
    May 04 2007
    Northeast
    Quote Originally Posted by chris@fifteen52 View Post
    How much do the 18's and 19's weigh? Do you have these forged?
    Glut / Capristo / Baby Seats
    Oct 04 2012
    Everywhere
    Our wheels are made for strength and as such are not super lightweight, but made to last. The 18s weigh about 25-28lbs depending on widths and offsets and the 19s are 28-30. We can also do them in 1, 2 or 3 piece forged and many other styles as well. Our forged wheels are all custom to your specs.
    Stage 2 Banner Advertiser Four Rings HRE Wheels's Avatar
    Mar 10 2011
    San Diego, CA
    Can't seem to find any RS4 photos that I have with those exact wheels. In fact the closest thing that I have would be this S5 with HRE 301M Wheels in Satin Black.
    I have a couple more photos up close so you can see more detail in the wheel and in the finish too in the satin finish that you're feeling out. Here's a brushed titanium finish:
    Here's a satin gold finish:
    Feel free to post back any questions you have or send me a PM and I can help out some more :)
    HRE Performance Wheels.
    Oct 13 2014
    Quote Originally Posted by torquesteer View Post
    Do you have a picture of how those look on your RS4? I came really close to buying the same wheels for my RS4.
    Mar 02 2012
    RS4 & RSV4
    Quote Originally Posted by Eric F View Post
    Yep, here you go. My car is at stock height.
    - Quan
    Jan 15 2010
    Santa Barbara, CA
    OK, deciding to go with the HRE 301M in an 18x9.5, to save as much weight as possible. Now I need to decide on the finish and the tire to use.
    For the finish, I'm debating between brushed dark and brushed tinted.
    Brushed dark:
    Brushed tinted:
    The car is Avus, no titanium package. I'm leaning towards brushed dark, since that seems like a pretty awesome finish, and still contrasts Avus.
    For tire size, 255/40 is exactly the same diameter as stock, and 265/40 is slightly larger. The more sidewall the better, and a 265 on a 9.5 wheel seems perfect. I'm going to run a 26" ride height all around - any opinions on whether a 265/40 will cause issues?
