2001.5 audi s4 avant asp stage 3 $6000 firm come get it
transmission shifts smoothly and i have no issues with 1-2 or 2-3 shift (forks are good)the car was hit in the back and It still drove great the car has sat for 6 months. The clutch slave master cylinder needs to be replaced along with the throwout bearing which failed and is the reason the slave failed.
car has 161k miles on it with 75k on the motor I have over $25,000 in receipts
FRONT CLIP IS NOT ON THE CAR ONLY HAS RIGHT FRONT FENDER and both wheel liners no front bumper or left fender
parts on the car
ASP installation of 2.7 engine(45,000 miles ago)
ASP Fueling- for k04'S 660cc injectors (dyno tuned)
ASP 3"Downpipes ver 2
ASP Tru dual exhaust 75mm tips
ASP phenolic spacers
ASP DTS
ASP LIghtweight crank pulley
Sterns motor mounts medium density
OEM rs4 trans mounts
OEM ko4 turbos (35k miles)
OEm rs4 clutch
Fidanza LWFW with new pressure plate when rs4 clutch was installed
Stasis track sports 900/800
Hotchkiss 25mm rear sway bar
Egt deletes
OEM rs4 headlights
APR vent boost gauge with red led light
Drive shaft shop axles with porsche 930 inner cv and upgraded outer cv good up to 800whp
Recarro SRD seats with custom alcantarra and leather to match OEM interior
Has all season summitomos on it with less then 10k on the tires on the stock avus rims
alcantarra Interior from Imola avant transplanted into Laser avant that originally came with black leather interior. as well as aluminum mirrors from imola transplanted to laser with red mirror caps
all new wheel bearings 30k ago
All new control arms 20k ago
New alternator 10k ago
New starter 10k ago
Timing belt, water pump, valve covers, etc done at 140k
mb quart speakers,
grom interface for ipod
jl amp
alpine amp
jl 12" sub
email me [email protected] with your phone number for fast response
this is what it looks like right now
started it for first time in more then 6 months, brakes are good (rear brakes and rotors are new) it needs some loving i have no time COME GET IT $6000 email me [email protected] with your phone number for fast response
