Results 1 to 37 of 37
    Jul 01 2015
    NS Canada
    Finally got to drive my s4 in the snow
    So I've been waiting for snow ever since I put on my azor 18x8 replicas + Alpin PA4 to see how it compares to the range rover.. short answer, I think this car crushes the Range Rover in terms of fun in the snow, as well as braking (duh), and acceleration. No kidding.
    About 15cm down, fluffy snow. Drove my wife to work, then spent the last half hour trying to get it stuck (fail.) This vid is an example of a hill (its taller than it looks) where someone with a crossover (FWD) couldn't make it up. I decided that would be a good place to try. I'm also dropped like 1.5". Nuts.
    I would definitely not recommend deep snow tires for this car, you'd be giving up way too much when there is no snow.
    So much fun and feel very confident taking this car anywhere now (except over frozen icy shit where its so low)
    Deactivated Three Rings
    Aug 24 2015
    "It's tooooo easy". man, you shoulda floored it up that hill. No balls.
    Sent from my iPad using Tap,Tap,Tapatalk
    Jul 01 2015
    NS Canada
    Wasn't necessary, and would imply it needed it to get over the hill. I wanted to test what it can do under normal conditions where someone else was stuck.
    Future video tho ;)
    Aug 03 2015
    Calgary
    Crushes the RR? What's that.
    Yeah, the S4 is great in the snow. I find that it feels less grippy in the corners than my M3, just because it's so much easier to gain speed before the corners!
    2011 B8 S4 DSG Full ADS & Sport Diff - U2nelson CR-15 strut brace review - Eurocode intake - S5 rear sway bar review - Eurocode transmission insert
    2005 E46 M3
    Sep 05 2012
    Quote Originally Posted by xtremepsionic View Post
    Wanted to say Rolls Royce :) , but it probably means Range Rover.
    2013 S4 Premium Package (Canada; like US Prestige) / Phantom Black Pearl ext / Nappa Black&Magma int / B&O, Nav, S-tronic DSG, Sport Diff, Michelin Pilot Sport 4 S wrapped around scuffed up 19" potato peelers / 3M See-through brassiere // GIAC/AWE Stage 2 + TCU tune - CTSTurbo Intake // Winter mode: 18" Nokian Hakkapaleno? R2 on RTX Ingolstadt gunmetal wheels (B7 RS4 knockoffs)
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Ground clearance would be my biggest concern
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    Wipers are icing up pretty bad.
    Senior Member Two Rings roadawg's Avatar
    Jan 09 2015
    You probably won't be able to get it stuck unless you high side it, or approach 15 + inches of sitting snow. Even then it prob won't stop it totally.
    I only have all seasons and it's super easy. Tricky part is do not get over confident and try to turn/brake. You will slide into a curb like any other car.
    2012 S4 - Man pedal, sport diff, APR tune, Meisterwerk SS, AWE Exhaust & other goodies.
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    I remember driving my car in 14 inches of unplowed snow with the Vredesteins on it. Unstoppable
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Jan 26 2015
    2017 XC90, a workbench
    CO
    My wife's MDX crushes my S4 in the snow. We both have Blizzaks. Don't get me wrong the S4 is still very good (although it's a snowplow since I am lowered) but my god her's is like a tank. I have driven around other cars/SUVs that were stuck on I-70 in the mountains during a blizzard like it was nothing. Now if I could just get rid of that power beak and give it more power.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Jul 01 2015
    NS Canada
    Range Rover
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Try a Subaru with the same tires...
    The S4 is good but with the slight bias to the rear wheels the back end kicks out too much for my liking. The GC8 i built was truly epic fun, with only 180hp its much more controllable even without traction control.
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Jul 01 2015
    NS Canada
    yup. I'm picking up winter blades today.. the oem ones are good in the summer but are useless for winter
    Quote Originally Posted by Senseless View Post
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by SDV325 View Post
    Leave nanny controls on and put it in comfort mode. With TC, Stability control and the power then shifting via AWD it shouldn't kick the back end out much if at all.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Apr 22 2013
    maine
    My A4 does this pretty quickly as well. Only way to prevent it is use defrost at full fan speed. Kinda annoying.
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Quote Originally Posted by pdqgp View Post
    I have to agree with the other guy - on my 2014 with TC/Stability/comfort turned on the rear is definitely easy to kick out, then you hear that weird shuddering noise of TC killing power and tucking the rear back in.
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Jul 01 2015
    NS Canada
    Are Aliens trying to send me a message?
    Aug 03 2015
    Calgary
    Interesting thought. I had a 07 wrx before with proper winter tires and i sold it because it understeers too much on snow. Drove 6 years in snow with a e46 m3 after that, and this is the first year in the s4.
    I find the s4 to be damn near perfect, sport differential set to dynamic and it's pretty loose, diff in auto gives great traction and stability.
    I guess we're all used to different levels of oversteer, no right or wrong. Personally I love the feeling of the car on the limit of adhesion.
    Sent from my LG-D801 using Tapatalk
    2005 E46 M3
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    My 2016 S4 will never intentionally see the snow. She'll remain a garage queen when snow, sleet, or ice may happen into my area. My 2004 Acura TL enjoyed the same treatment.
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Quote Originally Posted by SouthernBoy View Post
    So you'll take the Lambo out instead? LOL, stop it man. Its an Audi it WILL no matter what you do lose value year over year. You won't get more money for it when you sell it because its never been driven in the rain or snow. Drive the damn thing.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    Hey!! So I'm not the only one with an Audi that's a garage queen! High Five!
    Active Member Two Rings Starman2112's Avatar
    May 06 2014
    Chicago
    FACT: 10 out 10 Garage Queens love to put on the hooker snow boots and do donuts around m3s.
    Senior Member Three Rings Moto One's Avatar
    Mar 26 2010
    C5 Z06 (going on 17 years)
    Tahoe/Truckee
    My only real concern with the S4 is snow pack in the wheel wells. On a over night trip to Colo. (Many years ago in our 1984 4000s) driving in snow all the way I cooked a set of snows. But then a 900+ mile Sub Zero jaunt, the car was only surprised once on glazed hard pack. Then again with our Sierra Cement, Iv been stuck in less then 2" just spinning wheels.
    Mark
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by blackfunk View Post
    ^^ this. It's just a car. It's a sedan not a Gulf livery Ford GT or anything special.
    My son laughs that I like to take my S4 out rain and soon to be snow. IMO that's when it really shines.
    I had a CTS-V and a very nicely done up one next to me this week on a cold 38* day with damp roads. He couldn't hook up to save his life. Props for sounding good and trying though. I eased into the gas the first light. The next light however I did a full bore launch control take off from a mere 3k. Spun enough to twist the back end just a bit but she straightened out with ease and left him 1/2 mile back. I never saw him after that but I was grinning
    The S4 is a car that can be enjoyed full-on nearly 100% of the time.
    Established Member Two Rings fillyo's Avatar
    Jan 22 2015
    Chicago, IL
    Love driving in the snow, this is my first winter with the S4 and snow tires (last year had a 335i with winters). I also have the Alzor reps with LM-60s, this thing is incredible in the snow. Only thing I worry about is clearance, especially if its a heavy thick big icy block in the middle of the road, don't want to damage the front end.
    Phil
    2011 S4 Prestige | Ice Silver | 6MT | SD w/ ADS | Silk Nappa | Nav | Carbon Atlas | Blind spot | B&O |
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by fillyo View Post
    I worry more about Ohio pot holes! I have a separate summer set up and use the Stock 19" peelers and LM32's for winter. Still would hate to damage a tire/wheel though.
    Junior Member Two Rings =Law='s Avatar
    Dec 26 2014
    2014 Q5 TDI
    Calgary
    2011 S4, 6MT, B&O, Navi, Sport Diff, Unitronic Stage 2, S-Flow Intake
    Jan 30 2014
    Drove my car in the snow for the first time with Continental DWS06 and was pleasantly surprised how good they were. I guess anything is better than the summer tires my rotors came with. Lol
    2014 Audi S4 Glacier White, 6MT, Black optics, Alcantara, SS inlays, Nav., H&R OE sport, Cts Turbo intake, custom exhaust
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Quote Originally Posted by Moto One View Post
    Mark
    Don't worry about it. You're talking about a 32 year-old car. It's akin to comparing an F150 with a bed cover to an RV with built-in jacuzzi. You can drive through half a foot of snow all day long and it won't bother the car at all. The cars today are designed to not pack snow into the wheel wells so tight that it would cause problems.
    Nov 28 2015
    Montreal, QC
    I'm curious how it is driving a dropped car in the snow.. ?? do you think it will end up being a problem down the road ? fluffy snow is fine, but i can see heavy snow damaging the front bumper for exemple ?
    Jun 03 2014
    Virginia
    Sorry, ain't gonna happen... for three reasons. 1) It has summer tires. It seems Audi, in their infinite wisdom, elected to shoe this car with 'H' rated A/S tires if you decide to get all seasons in lieu of the summer shoes. But doing so means that Audi sets the speed limiter to 130 MPH. Not wanting this, I went with the summer tires which are not recommended to run when temperatures fall below 45 degrees F. And definitely not in snow. 2) My driving machines don't see snow... period. Nor do they see parking lots with tight spaces or valet lots or anything I don't like. That's why I have a truck. 3) It's my property. I'll decide what I do with it.
    Jun 03 2014
    Virginia
    Quote Originally Posted by StealthBlackA4 View Post
    Yep, you got it. That's what my garage is for; my and my wife's cars.
    Jun 03 2014
    Virginia
    I've driven in snowy winters for 50 years (1964 was the first year) so I am comfortable doing this. It's not me I worry about... it's others. Our area is so transient that we get a lot of people who just have problems when we get snow. Since cars don't heal, I prefer to protect mine by leaving it at home where it's safe.
    Besides I'm a Southern boy. I don't like snow, don't like the cold, and would rather I never see either one of these again (perhaps someday I can get down further south where I won't see anymore of this).
    Jul 12 2012
    Lotta rules for that car man. When I was a kid my dad always used to tell me 'Son, a car is a tool. You use it as such. Do you fall in love with a hammer? No. So why fall in love with a car?' I laugh now because I can clearly hear him saying it. LOL. Listen I can't tell you what to do with your property, obviously - but whats gonna happen if you get into a fender bender or such? The value in the car is in its usage, not using it isn't getting much value out of it.
    Clearly we have a difference of opinions but I'm just sharing my side, not trying to pick a fight with you.
    Jun 03 2014
    Virginia
    It's a matter of property and a measure of pride, I suppose. I've always been this way and every gearhead I have know was the same way with their street machines. It's just how we think. I find that most people think of cars like washing machines. They are no more than a point A to point B device. I'm not like that. And I am anal has hell about what's mine, be it my house, my driving machine, or most anything I own.
    "..not trying to pick a fight with you."
    Never thought you were. That would be ignorant in my book, since we don't know each other. We just happen to have a different approach to the subject.
    May 01 2014
    New York State
    I subscribed to this same philosophy at one point with our viper and then our challenger SRT8. Never again will I purchase a car and not drive it whenever the hell I want. Obviously a viper is going no where in the snow. But we babied that car to death - chance of rain, stays covered in the garage. I drove the challenger a bit more but wish I had driven it more.
    It's here! - 2015 S4, Sepang Blue, 6MT, Sports Diff, etc
    Mar 26 2010
    Tahoe/Truckee
    Quote Originally Posted by hotleadsingergu View Post
    I wish I had pic's form Christmas Eve drive home from the valley, the wheel wells on our B8 S4 were packed and it did like the driveway transition, and don't ever think that a tall vehicle can conquer 6 inch of old pack spring snow or the set up plow berm. I'v been stopped more then once by it with both our old allroads, Suburban,and Range Rover. Then fresh dry powder is a a different story, just keep believing all the 4X4 tv commercials. I'v been involved with making them, and that after edit look really good. What you don't see is the PA's digging out the stuck subject vehicles.
    Mark
