So, I've been going through gas at an alarming rate. Something to the tune of ~150 miles to a tank.
After running the readiness test on VAG Com again, but under the proper circumstances; the only thing that was listed as failing is the catalyst/catalytic converter.
However, there are two codes (17521, 17539) which refer to 02 sensors which also may be what's causing the low gas mileage. In other words, I have no idea what needs replacing and what should be left alone.
Also note that I haven't had a CEL from the 02 sensors, which makes me think that they're possibly fine.
