Results 1 to 6 of 6
    Dec 14 2015
    1990 G60 Corrado
    Vancouver, Wa.
    Question Local (PDX) Locksmith that can cut the VAG "Switch Blade" keys
    Hello everyone,
    I was wondering if anyone knew of a Portland/Vancouver area locksmith that can cut the "switch blade" keys for an Audi (B6 S4)/
    I received two new blank/fobs for Christmas. I think I may be able to program them myself using a generic Hex-Can cable and VCDS, but I don't want to have to have pay an Audi Dealer to do the whole thing.
    I have seen references that some locksmiths and even some Home Depot/Lowes have the newer machines that can cut the switch blade keys.
    Anyone local have experience with this task?
    Veteran Member Four Rings CupcakeS5's Avatar
    Jul 18 2009
    Your mom
    You are going to run into issues with the immobilizer if you don't have the FOB programmed to your cluster. It's not a DIY thing - typically the dealer needs to do this because we car owners can no longer obtain the SKC code necessary to do this ourselves.
    I know violence isn't the answer. I got it wrong on purpose.
    "Then you get ecodes, and it's like beer tastes better, tits are perkier, and things are just right in the world." -i1overice
    Senior Member Two Rings viciousone's Avatar
    Oct 04 2013
    PDX Area
    You can always take out the original blades from your old key fob and put it in your new ones.....but then again you will need to be able to get the remotes programmed.
    vIcIoUsOnE-"Go Hawks"
    _______________________________________________
    R8GT/ "Lorraine"
    S4 B5 Avant Stage III AMD Tuned "Scarlett"
    SQ5 B8.5 Black Optic/Tech/Diamond "Lady Jaye"
    GOLF R MK7.5 "Wonder Woman"
    Dec 14 2015
    1990 G60 Corrado
    Vancouver, Wa.
    Post
    Looks like I need to do some more reading.
    This was the source I was going to use to program the new FOBs:
    http://www.audizine.com/forum/showth...mming-with-VAG
    I do see a reference to a "Remote Control Matching" thread on the Ross-Tech site:
    http://www.ross-tech.com/vag-com/car...-matching.html
    And the Remote matching page clearly states that This does NOT show how to match Immobilizer components, see other items on the "Car Info & Procedures Page" to do that.
    http://www.ross-tech.com/vag-com/cars/index.html
    Which in turn has a link to Immobilizer info for VW/Audi/Seat/Skoda:
    http://wiki.ross-tech.com/wiki/index.php/Immobilizer
    Assuming I have the Gen 3 immobilizer, this excerpt from the Ross-Tech site has a few methods. I will do some more reading. Reading is free, maybe I'll get lucky and not have to go to the dealer. Then again maybe I'm just fooling myself, but I am sure to learn something along the way.
    Copied from the Ross-Tech site
    [Immobilizer Generation 3
    Many 2002 and newer Model Year vehicles sold in the North American Region (NAR) have Immobilizer 3 and there are other Rest of World (RoW) Vehicles with Immobilizer 3 as well. Use VCDS to Select the Instrument Cluster (or Address 25 - Immobilizer in Vehicles with a separate Immobilizer Control Module) and look in the Extra Field. You should see BOTH a 14 digit Immobilizer ID number and ALSO a 17 digit VIN number in the Extra fields like this: WVZKB58001H231169 VWZ7Z0W0648696. The first 17-digit string is the VIN and the second 14-digit string in the Immobilizer ID. Keys that have been previously matched to a different Immobilizer 3 System cannot be reused with another one (which has a different Immobilizer ID). In some cases, you'll need to check in the Engine Control Module in Measuring Value Block (MVB) 081 to see the VIN and Immobilizer ID. If in doubt, check the Factory Repair Manual for your specific vehicle.
    Key Matching (through Instrument Cluster)
    Key Matching (through separate Control Module)
    Key Matching (through Kessy)
    Engine Control Unit (ECU) Swapping
    Injection Pump Swapping (V6 TDI only)
    Immobilizer Control Module Swapping (integrated in Instrument Cluster)
    Immobilizer III Immobilizer Swapping (Separate)|Immobilizer Control Module Swapping (integrated in separate Control Module)
    Immobilizer Control Module Swapping (integrated in Kessy)
    Immobilizer III Measuring Blocks (Ross-Tech Website)I][/I]
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    You can contact Chad at SOS Diagnostics. He can at least cut the key blades for you; http://sosdiagnostics.com/contact.html
    I don't believe he can do the key coding for immobilizer, but ask him.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Sep 16 2010
    Central Wash
    If you have a spare you can mail it to http://bulgerlock.com/ and they'll copy and return it to you.
    Remote matching is easy, shouldn't have a problem with that if you have the right remote.
    Immo is easy too, just need a couple pieces of software and a Hex-Can cable. I do it all the time, ECU's, Clusters w/ Odometer correction, keys...not so technical these days.
    All these systems eventually get hacked.
