Results 1 to 26 of 26
    Mar 27 2008
    San Diego
    JHM Overdrive and Stage 2 without Supercharger Pulley
    I've been stage 1 for the life of my car(5 years) and am definitely tempted to go stage 2, however, with crank pulley failures becoming more common it seems a more cost effective strategy may be to go JHM overdrive and stage 2 software.
    Is anyone running this setup? Also does anyone know what tuners will install their stage 2 software without sale of one of their pullies? I have Revo tuning who I believe will sell the update but I think some other tuners will not. I'm definitely not looking to "double up" with both a supercharger and overdrive crank pulley.
    Established Member Two Rings s4_209's Avatar
    Jun 18 2015
    2015 S4 & 2015 A3
    I've been running this setup since 1,200 miles. Have about 6k miles now. Got the crank pulley before it came out. 1st customer with it :). JHM did the install and it came out a bit cheaper since the labor didn't take as long as a supercharger pulley install.
    APR Stage 2 Tune, APR DSG Tune, JHM Lightweight Overdrive Crank Pulley, AWE S-Flo Intake, Dinan exhaust, ECS Slotted Rotors, Akebono pads, Bilstein B12, 034 Motorsports Inserts, 19" Avant Garde M510, 255/35 Michelin Pilot Supersports, 35% tint all around, Blacked out Ambers, Fogs & Grill
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by s4_209 View Post
    Did you still have to purchase APR's pulley to get the stage 2 software?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Been running this setup for a few months, its been working well and Revo let me flash to their 1+ file without buying their pulley.
    Edited:
    We just installed the overdrive pulley on a friend's SQ5 and APR forced him to buy their pulley to flash to stage 2.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Jun 18 2015
    2015 S4 & 2015 A3
    @LINDW4LL - No, JHM took care of the supercharger pulley so I got credited for it.
    Mar 27 2008
    San Diego
    Quote Originally Posted by fitzydude View Post
    Been running this setup for a few months, its been working well and Revo let me flash to their 1+ file. We just installed the overdrive pulley on a friend's SQ5 and APR allowed him to flash to stage 2.
    This is good info; so it looks like Revo and APR are selling stage 2 without a pulley sale now.
    Out of curiosity how how long does the crank pulley take to install? One of the downsides for me was that to install the crank pulley the shop wanted the car basically all day to let it cool and then do their thing and as it's my only ride wasn't very feasible.
    Veteran Member Three Rings blingaling's Avatar
    Feb 12 2011
    05 ninja 636(RIP)
    NEPA
    Wait so you dont need a smaller S/C pulley if you have the jhm overdrive pulley?? I didnt know that one. Is the diameter smaller on the jhm crank pulley? I never knew or looked into that yet
    Sent from the brick shithouse
    Jul 05 2014
    Houston
    Quote Originally Posted by jeffc31337 View Post
    Maybe 6 hours on the first try, got the car back together and realized I left a bolt out of the bumper support
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    How does the car feel with the JHM pulley? Curious if it feels any different than stock since it doesn't have the rubber damper.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Jun 18 2015
    2015 S4 & 2015 A3
    Quote Originally Posted by blingaling View Post
    Correct, you don't need the supercharger pulley if you run the OD crank pulley. It's actually larger in size than stock and lighter so it revs a bit quicker also.
    https://jhmotorsports.com/shop/catal...a8-p-3392.html
    Jul 05 2014
    Houston
    Quote Originally Posted by ntsantos View Post
    Feels no different.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    To clarify...I still had to buy the APR pulley just to get the stage 2 tuning code. I am thinking of installing it too, rather than just having it as a paperweight. That's why I'm perusing these threads.
    Much thanks to you guys for the help installing that. I believe I'll let Ryan do the SC pulley. He has those special tools. After doing some pulley math in another thread, I'm thinking about undoing the VAGCom mod to disable auto-upshift in manual, just to make sure I don't over-spin that bitch.
    Jul 05 2014
    Houston
    Quote Originally Posted by SQive View Post
    My bad! I should have remembered you saying this, It didn't click that you were forced to buy it.
    Veteran Member Four Rings PinoyS4's Avatar
    2018 catalunya RS3
    sf bay area
    I'm running this dual pulley (JHM/APR) on Apr stage 2 tune. Patiently waiting for their dual pulley tune and b8.5 stalk switching set up.
    work hard, play hard[;)
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    It seems that Dual Pulley Set up + Full E85 MAP could be a verry smart Stage 3 !
    BR
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Comfort wise you shouldn't notice anything. Performance wise you should feel a nice bump
    Senior Member Three Rings Audi0005's Avatar
    Jan 12 2006
    ottawa. Ont
    i'm currently stock and i would like to get stage 2 in about 5 months after warranties up.
    am i understanding the above correctly?
    all u need is apr stage two software and overdrive pulley?(no need for the apr pulley ?)
    Mar 12 2014
    Long Island, NY
    Quote Originally Posted by PinoyS4 View Post
    Did you notice a difference installing the JHM pulley on top of the APR pulley? I am stage 2 APR currently with their pulley installed, but I am looking at buying the JHM one if it shows gains.
    2013 B8.5 S4| APR Stage 2+ w/ UltraCharger on E40 | APR Dual Pulley | APR DSG Update | APR CPS | Awe Non-Resonated Downpipes | JHM Test Pipes | AWE Touring Exhaust 102mm | Alu-Kruez | JHM 2-Piece F&R | H&R Sport Springs
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    Like a few other people in this thread I guess I haven't been paying enough attention to this and it's news to me. fitzydude, about how much does Revo charge for the 1+ tune without a pulley? And did you have to jump through hoops to do it or were they fine with it? Thanks.
    Also, are there other downsides to this that I'm not seeing? It seems like a no-brainer if the price is fair.
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Szemenyei View Post
    If you are using OTS Stage 2 software your gains will be more torque down low because the blower will be spinning faster, bringing the boost in sooner. The peak boost will stay the same because of the predetermined bleed-off from the software.
    From a preventative maintenance stand point it is a no brainer, plus you get the added benefit of more power and less rotating mass. Win Win Win
    Jul 05 2014
    Houston
    Quote Originally Posted by LeadToRome View Post
    Revo pricing was really good!! With their end of year sale and a 10% discount from the dealer I paid ~900 installed for the software. There was some confusion getting reflashed from 1 to 1+ because my dealer and Revo had not heard of the pulley yet.
    About 48% of people here are concerned with putting an undampened on their car. The thought is the undampened pulley will create an imbalance and generate noise/vibration which will lead to excessive wear on your engine bearings. JHM has said of the engines they've disassembled with undampened/lightweight pulleys the bearings look as good if not better than the engines they've disassembled that had an oem dampened pulley. Personally, I've ran undampened/lightweight pulleys on several platforms over many miles and never had an issue. That's why I didn't hesitate to put one on my car!
    Mar 27 2008
    San Diego
    For those with Revo Stage 1 tuning the upgrade is only 50 dollars.
    Apr 25 2010
    I-95
    Nice, thanks for the info. I'm psyched, thanks.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    bump, does anyone know how long you can push your 55k service to swap in one of these pulleys? my pulley looks fine for now and im thinking about waiting to 75k
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Jul 05 2014
    Houston
    My stock pulley made it to 109k and still looks good. Are you stage 2? It seems the smaller sc pulley puts extra stress on the OEM pulley, so if your not stage 2 you have a chance of making it longer.
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    The JHM OD Crank Pulley is designed to work with OEM SC pulley and the JHM Non-OD Crank Pulley is for Stage 2 SC pulley, right?
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
