Results 1 to 15 of 15
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    What's your snow tire speed rating?
    Because I just checked mine. It's 99mph. That quick jaunt up at 120 yesterday could've ended badly. Just a heads up for any other idiots that drive like me.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Running Dunlop Wintersport 3D's on the B5 and Blizzak WS80's on the B8.5 both H-rated @ 130mph.
    On a side note, was in Germany for work and Europe has mandatory snow tires on designated months (MK7 GTI rental) had U-rated Conti's (124mph/200kph) and actually got it up to 235kph and they were super squirrley on the Autobahn haha
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Dec 05 2007
    Some provinces in Canada also requires snow tires. At least for the fronts. And I had my Blizzaks over 100 before.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    No. It's just certain roads like mountain passes you need them.
    Sent from my Jailbroken iPhone 6s 9.0.2 using Tapatalk
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Oct 09 2012
    Sorry. Only in Quebec requires them I guess but who the fuck knows why.
    In Quebec,all passenger vehicles are required by law to have winter tires installed on all wheels during the winter season effective December 15th to March 15th.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Dec 05 2007
    Didn't know all wheels. Also wasn't sure what provonce(s).
    Nov 07 2010
    South of Heaven
    In Canada you are mandated to have winter tires but they do not have to be arctic condition snow tires in all areas. As long as they have the snow symbol on the tire they are good to go in most areas. Where I live you only need winter tires although I know of people in the area I live in being denied claims because they had winter tires and not full snow tires so they can get you. In British Columbia there is also a minimum depth of tread that must be met as well. In any case I run arctic condition snow tires even though I barely see snow just in case but I don't know the speed rating when I really should. My commute can be anywhere from 80 - 140 kph and I have seen up to 160 kph a few times for little squirts as well. I really should look at the tires, in my head I was thinking 112 - 114 mph but I am not sure where I got that number from.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Nov 07 2010
    South of Heaven
    I checked mine today and it is a Q rated tire which is good up to 160 KPH which I actually exceeded today on the way home.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    Dec 03 2014
    1999 Audi A4 Quattro Avant 1.8t 1998 BMW 328iC 1986 BMW 528e
    United States
    Something you guys need to know about speed ratings on tires. http://www.ntb.com/tires/Tire-Speed-Rating-Education.j
    The relevant bit from that link:
    What does 'Up to 99 mph' really mean?
    Tires with a Q speed rating can safely sustain speeds of up to 99 miles per hour. The tire may be able to reach higher speeds, but going faster than 99 mph for any length of time is not safe. The tire is not designed to handle the stresses.
    The main thing speed ratings are for is sustained operation at those speeds. It mostly has to do with its ability to dissipate the heat generated at speed. For tires feeling squirrely at speed is a much better indicator that you should slow down.
    As for my tires, I have Bridgestone Blizzak WS-60 rated 'R' for 106 mph sustained operation on my A4 Avant and 98 328iC and these feel good at speed. I'd have no qualms driving them faster than rated for short bursts. We have Goodyear Ultra Grip Winter on my wife's car. They're rated T/118 mph but I wouldn't drive those above 80 because of the way they feel. If you're looking for good snows with great dry road performance, look at the Michelin X-Ice tires. I've run them before and you really don't give up much on dry roads.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Veteran Member Three Rings Sumo337's Avatar
    Jan 07 2015
    2011 B8S4
    Pittsburgh, PA
    Hankook Ipikes are rated T (118mph)
    2 nights ago I hit 115mph in the tunnels.. Was smooth.
    @chetbagged
    2011 B8S4 Prestige
    460HP-384TQ Manual
    APR / ECS / P3 / WCI / Sportshifters / Polo Performance / Airlift / Caractere
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Blizzak WS50 with R rating so that's 106mph they have seen that many times. Eh I didn't know they had such a low rating. They always did seem a little unhappy at 110+.
    Sent from my SM-T560NU using Tapatalk
    SOLD the GOINHAM A4 ---> GT2860 Project
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by richardodn View Post
    This is the point I wanted to make. Speed rating doesn't mean you can't go over that speed, it means you cannot sustain speeds above that.
    I'm not sure what the speed rating on my winter tires is, but the car never sees above 80mph. Its winter, no need to be going that fast. Plus, my fast car is put away.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Dec 23 2009
    Boulder, CO
    Quote Originally Posted by redline380 View Post
    Wrong, winter means cold air, thus more fast
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Avant Nate View Post
    When I put my car away, it was the first time I ever blew a charged pipe. Put it back on and the thing was running like a raped ape. All in sub freezing temps.
    But no need to have it running in the winter. I got an Avant for that stuff.
    2000 S4- Working?
    Oct 09 2012
    this.
    EDIT:
    Assuming the interwebs is correct my tire speed rating is 'S' 112mph/180kph which i have gone up to but not exceeded.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
