Results 1 to 6 of 6
    Sep 28 2006
    Lexington
    07 Audi A4 3.2l MAP/MAF Problems
    So, I have been having a few codes lately and I want to know where the MAP/MAF sensor is, so I can clean it. I will also clean the throttle body in the process.
    Can I clean the throttle body with it still on the car? I have already looked up the codes, but need a little help on getting this problem fixed. I think it is causing me to have MPG issues.
    004440 - Manifold pressure sensor (g71), implausible signal output does not have contact/short to earth
    000104 - MAP/MAF throttle position correlation output does not have a contact/short to earth
    Sometimes when I'm starting the car it will start and then die. I try it again and it hesitates and then starts. Sometimes I have to give it gas on the second try.
    Thanks
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Sep 28 2006
    Lexington
    Bump! I still can't figure out where and how to fix this problem. Thank you!
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    judging by the fault it seems you have an open circuit coming from the sensor. You may want to check that first....
    Sep 28 2006
    Lexington
    Quote Originally Posted by miA4 View Post
    But where is the sensor on the 3.2l?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Jul 17 2015
    miami
    from what I read, it is behind the throttle body.
    Jul 17 2015
    miami
    http://www.audiworld.com/forums/a6-s...-2-v6-2766100/
    this may point you in the right direction.
