    Senior Member Two Rings tomahawk297's Avatar
    Jul 25 2014
    Mississippi
    Question Mechanic says ballasts don't need programming?
    So I've just brought my car to my mechanic because my brand new headlight assemblies don't work except for the turn signals and daytime runners. I tell my mechanic that I'm pretty sure they just have to be programmed to the ECU and he says that ballasts don't need reprogramming even when replaced but he will go in and "reset" them even though he doesn't think this is the issue. Does this sound right or does he not know what he's doing? Thanks.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by tomahawk297 View Post
    What headlights? OEM? Aftermarket? Factory xenon? Aftermarket xenon?
    Mar 24 2013
    Oakdale, CT
    If swapping from halogen to oem bixenon, there is coding that needs to be changed.
    -Adam
    Veteran Member Four Rings Shanster's Avatar
    Jun 02 2011
    2016 B8.5 Allroad, 2022 Volvo XC90 T8 Recharge R-Design
    Maine
    If swapping ballasts from old OE Bi-xenons to new OE Bi-xenons, you do not need any coding.
    Brent
    2016 B8.5 Monsoon Gray Alload
    Sold: 2007 B7 A4 Avant 2.0T 6MT, 2014 B8.5 Ibis White Alload
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by Shanster View Post
    Yes and No
    If the ballast version (software level) is different, you will need to recode. If same version, you are OK
    In your case, the version must be different and you need to marry the new ballast to the ECU
    http://www.audizine.com/forum/showth...ast+adaptation
    Phil
