I currently have my car apart. I am not going to be able to use any of this stuff for my setup is changing. If you have any questions feel free to ask.
All of these parts are in good condition.
1.) ARP 3 inch turbo inlet pipe. $80
http://s482.photobucket.com/user/KHA...tml?sort=3&o=6
2.) ECS tuning test pipe/ cat delete ( no cracks, good test pipe just can't use it anymore ) $50
http://s482.photobucket.com/user/KHA...tml?sort=3&o=5
3.) APR Carbonio intake. ( The carbon fiber top has no cracks in it, i have all the hardware for it. The MAF sensor will not be sold with it. The stock MAF housing can be sold with the kit for i don't need it. I believe i can dig up the instructions somewhere and put it in the box. I'm sure APR's website has them .pdf. Also comes with the small filter for the SAI pump feed that usually connects to the stock box but you will be removing that. Also comes with a cone style air filter to meet with the MAF housing through carbonio intake panel, its pretty dirty i did not clean it, i did however clean the kit up though.
http://s482.photobucket.com/user/KHA...tml?sort=3&o=4
http://s482.photobucket.com/user/KHA...tml?sort=3&o=2
http://s482.photobucket.com/user/KHA...tml?sort=3&o=0
4.) I have the whole SAI system that was working perfectly fine when i took it off. No incorrect flow stuff. I do not have photos of the SAI pump or anything else photobucket is moving slow. As soon as i removed the pump i taped up both the ports on the pump so no dirt would get in there. I'll sell the whole system with combi valve and all the hoses (metal, rubber, and plastic) $100 Buyer pays shipping.
Thanks for looking! 301 710 3562
