Results 1 to 10 of 10
    Aug 09 2012
    2013 S4 phantom pearl
    IL
    engine reinstall, quick mount question before I proceed
    so I bought 034 engine mounts for my build. doing my reinstall. I marked both of the aluminum engine mount brackets underneath where the previous engine mounts were bolted through, but I think the markings were washed away when I cleaned the bay. anyway, got both mounts lined up and dropped the engine in. I installed the mount screws in the center holes on both.
    issue is, I went underneath the car to start connecting my linkage and the trans and downpipes are skewed left toward the passenger side. this would mean I'd have to relocate the driver side mount to the rear hole. does this sound accurate? I could've sworn both of my previous mounts were positioned in the middle. it's worth noting I converted this from tip to 6 speed, not sure that would matter whatsoever.
    Jul 20 2011
    Providence - RI
    Can't tell where they were from the washers and screws use to be?
    Aug 09 2012
    IL
    I looked, and I see markings from the center. but then again, I washed the bay and everything throughouly so I'm struggling to say yes definitively.
    there's no way this thing is right as it sits. something is off. the driver side downpipe is 1/8" from touching the heat shield. passenger side has 3"+ of clearance. trans is also skewed left
    Jul 20 2011
    Providence - RI
    Yea. That doesn't sound right. I'll take some pics when I get home tomorrow.
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    Not sure if this will help you or not, but here's where my factory mount sat.
    2002 Pearl/onyx S4 Avant
    Aug 09 2012
    IL
    do you have a pic of underneath? it's the driver side sucker that seems maybe out of whack. 034's top and bottom mount nuts aren't offset, correct? they seem pretty centered
    Aug 09 2012
    IL
    okay so this gets a little more funky or simple. I just tried installing the trans mount center bolts and voila, they go in like a charm. so if the engine mounts were off from where they should be mounted, the trans mounts shouldn't line up as the subframe/frame rails haven't changed one bit in this entire thing.
    so why in the hell is there so little room for the driver downpipe and trans skewed left toward the drivers side? is that normal? I don't want to button this thing up and be off kilter
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    I can't find a pic of the passenger side. Here's the driver's side:
    Aug 09 2012
    IL
    that's how mine is. looks like everything is lined up the way it is. that driver side downpipe is pretty close. I also measured distances from each side of the engine fromt and rear to the firewall. they're identical. it looks like it's correct. most likely the am downpipe is much larger than stock and that's why it seems so much closer
    Jul 20 2011
    Providence - RI
    I'm back at home. Pm me your cell number and I'll text you some pics. It's just easier thst way.
