Results 1 to 10 of 10
    Jun 16 2015
    2015 A3 Glacier White Prestige (traded in)
    CA/NM
    2016 Sq5 oil question
    I was heading home from the airport, after a week of holiday vacation, about 30 min into the drive all of a sudden my oil light turned on and told me to add 1 qrt. It's odd bc I had my 5k service at the beginning of Dec.
    I do live in an area with cold to freezing temperature and it was freezing (to me, about 20 to low teens temp) during the holiday weekend. My car was parked at an outdoor, but covered, airport parking for a week. I'm still new to living in the cold, so was wondering if this a common thing? I read the Q5 had oil problems in earlier versions, so I monnitor my oil levels from day 1 thru the MMI. I didn't see anything wrong.
    I took it to the dealer right away and was told that they might have added a little too much oil( at the max line or so) during my service and now the oil expanded with the changing temp and engine heat. They said normally the oil is filled to below the max line just a tad. But I don't get why the car would tell me to add more oil then? I was also driving the car for 2 weeks at 50mi/day after my service and nothing happened.
    I also asked if there was a leaked or anything, but the service manager said nothing was leaking.
    I had a 2015 A3 2.0T last winter and nothing like this happened. Although, that car wasn't inactive for more than 4 days during the winter.
    So basically, I just want to hear what y'all think is going on.
    Thanks in advance.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    The oil-level sensor may be beginning to fail.
    Is this continuing, or was it just a one-time fluke?
    Jun 16 2015
    CA/NM
    Quote Originally Posted by SQive View Post
    This is the first time it happened. So idk if its bc of the cold weather and long inactivity or they messed up my 5k service (idk how, but I wouldn't be surprised since this dealership is not very good). I monitor my oil level the day I got the car and it was always full. I guess we'll find out if it's the sensor...fingers crossed.
    Mar 21 2015
    Get a dipstick
    Jun 16 2015
    CA/NM
    Get a dipstick
    I might have to. After reading the old threads about oil problems, didn't think I would need it for the 16' model. I'll wait to see if this happens again. Hoping its just the oil overfilled or the sensors.
    Mar 21 2015
    Don't rely on electronics
    Jul 26 2015
    ATL
    Don't rely on people:
    Quote Originally Posted by Ronnie Schreiber at The Truth About Cars
    Not far from my home in suburban Detroit, I was driving south on Southfield Road, where the road becomes the onramp to the northern end of the southbound Southfield Freeway. As I accelerated from the last stoplight, I felt something unusual from the gas pedal. By the time I was on the ramp I realized something was keeping the throttle open. I fiddled around with my foot to make sure it wasn’t a water bottle or something else on the floor jamming the gas pedal as I considered that I was going too fast for the heavy traffic, too heavy to try to stop completely and, in any case, there wasn’t a shoulder there for me to stop.
    The tachometer was right around 4,100 rpm. The SOHC Saturn 1.9 liter motor isn’t exactly gutless, but you really have to keep it above 3,000 rpm if you want to accelerate briskly —4,100 is certainly in the sweet spot in the power band.
    I tapped the brakes and while they kept the car from accelerating, the pedal felt unusually hard. That’s probably because I’ve never braked under heavy throttle before. That’s when I realized it was pretty serious; no panic, but things definitely weren’t cool. I rode the brakes, figuring it was confusing the driver behind me since I wasn’t slowing much. Then I shifted into neutral, which at least kept the car from accelerating more and kept the brakes from fading. By then I had to make a decision, stay on the freeway or pull off at the first exit, which meant getting over in a hurry as it was approaching quickly.
    With the transmission in neutral, the engine started to oscillate up and down a couple hundred revs, almost like it was hitting a rev limiter, which this engine doesn’t have and in any case, that’s way below the redline so I wasn’t worried about throwing a rod or some serious damage. Still, something was not right and I had to get the car safely stopped. As soon as I got up the ramp, I turned down the first side street, and with the car still in neutral I stopped it, shut off the ignition and then shifted the transmission into park. Dropping it into park at 4,100 rpm probably would not have been good for the transmission’s parking pawl, or the transmission mounts.
    Looking down into the footwell, I could tell that there was nothing obstructing the gas pedal, so I got out to check under the hood. I caught a whiff of hot metal — likely the brake rotors — as I walked to the front of the car. When I opened the hood I discovered that I had done something stupid the day before which caused the problem....
    After my little episode of unintended acceleration, once I got the car safely stopped, I discovered that when I went to put away the funnel I was using to get the fluid into the dipstick/filler tube, I had forgotten to put the dipstick back. I don’t know how it stayed where it was on top of the engine for almost 400 miles of driving, but by the time I was entering the Southfield expressway, the plastic pull-ring on the end of the dipstick had managed to work itself around part of the linkage for the fuel injection throttle body, preventing it from returning to the idle position.
    Excerpted from http://www.thetruthaboutcars.com/201...drivers-panic/
    Jun 16 2015
    CA/NM
    UPDATE: So a little less than month after the dealer removed some of the "overfilled" oil that they did at my 5k service . The oil light came up again this weekend after driving for about an hr. I regret not ordering the dipstick sooner because I was driving nervously. The light came on saturday night and of course everyone is closed on Sunday, especially the only crappy Audi dealer in NM. The good new is tho the oil light went away after I opened and closed the oil cap. I didn't smell anything burning when I looked under the hood, so that's a relief.
    I'm guessing it is the oil sensor. Anyone have similar problem or any idea?? I really want to know if its a car problem or this ridiculous dealer actually screwed up a simple 5k service that bad...
    Mar 07 2004
    2025 Q7, 2018 TTRS, 2022 Q5
    Charleston, W.V.
    I bought a dipstick and it's not the correct one for my TDI. If you find the part number for the one you need I may have it. I paid $29 shipped for it, but it took 6 weeks to get it.
    Jun 16 2015
    CA/NM
    Quote Originally Posted by BarryT82 View Post
    the part number is is 06E115611H
    I got mine from here https://www.ecstuning.com/ES280765/
    I hope it's not gonna take 6 weeks lol. They said its in stock and it shouldn't take that long to ship within the US...
