Originally Posted by
belzebutt
I was looking for a DIY for this for a long time, thanks! What are the steps to actually take off the cluster? You remove the MMI surround, you remove the vent surround (making sure the vent doesn't explode). Then how many screws hold the instrument cluster and where are they? Any tricks to taking off the connection? Oh yea and I'm talking about the B8, I don't know if it's different than B8.5.
Pretty much what you said. It's pretty much a straight to the point mod that you can't screw up, besides the driver vent.
B8.5 the whole cluster trim comes off in one piece.
B8 Steps:
1. Take off the trim on the right side of the cluster (the part that goes around the screen).
2. Close the driver side vent so if it does fall apart, it holds all the pieces, then remove it.
3. The plastic piece between the lower part of the cluster and steering column, remove that.
4. There's 3 screws holding the cluster on, remove those.
5. Pop the cluster out and be careful not to pull too much since the wires are short.
6. Disconnect the harness in the back of the cluster.
7. Repeat backwards for install.
Pics of my install are on page 8 of my build thread. I didn't do a DIY though.
