Results 1 to 4 of 4
Thread: Sub woofer
    Dec 28 2015
    Eastern shore
    Sub woofer
    Hey I have a 6 ohm 250 watt sub
    And want to know if is possible for my 300 watt 4 channel amp to power it? If so how?
    Sep 02 2008
    Boonies VA
    What amp is it? You should be fine to just wire it up as normal. But, just be aware that it may not be as loud as you want due to the impedance of the sub.
    White Wagon
    Stage 2 Banner Advertiser Four Rings Christian@enfig's Avatar
    Jul 12 2004
    2013 CC Executive Edition VR6 3.6, 2003 GLI VR6, 2005 A4 cab 3.0 V6, 01 GTI VR6. Past 89 & 78 Golf
    Carlstadt, NJ (outside of NYC)
    Yes if you connect a 6 ohm sub to 4 ohm amp you are wasting power but it will work.
    EnfigCarStereo.com - Audi Car Audio Integration Specialists
    ☎201-490-5015 - Instagram - Facebook - [email protected]
    Want to make some money while posting? Join our affiliate program.
    Dec 28 2015
    Eastern shore
    So would a 1000 watt mono amp at 2 ohms
    Sufficiently power my 250 watt 6 ohm sub ?? Thanks a bunch
