My CEL is on on my 05 USP and having a hard time figuring out why. From my forum searching it looks like most people have problems fueling up their vehicles because the venting system for the fuel tank is plugged. Oldguy had a great few posts troubleshooting this, but I haven't had any issues fueling up the car lately. I noticed this last week, but it's in the perfect line of sight where I can't see it, so not really sure how long it's been on. I'll fuel up tomorrow, but doubt anything has changed. My scan is below.
Only observations I have are that the boost at idle or rather vacuuming has slowly been creeping closer to 0. Originally I think I had just shy of 20inHg when I installed it. Now today it's just below 10inHg but boosts fine to about 11-12 PSI. I know I need to get in there and diagnose which line is bad, but that will need two people. Have one guy pinch lines under the hood that should have vacuum and have the other guy monitor the boost gauge.
I'll have to research that oil sensor code as well, that's something I haven't seen.
Monday,28,December,2015,13:39:38:52715
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.com
VIN: License Plate:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: Mileage:
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 BC HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0010
Revision: 00000000 Serial number: AUZ6Z0D0234637
Coding: 0016711
Shop #: WSC 63351 000 00000
VCID: 72EB6FD76E62CAAE5B-5122
1 Fault Found:
16826 - EVAP Emission Control Sys
P0442 - 001 - Small Leak - MIL ON
Readiness: 0000 0000
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01231
Shop #: WSC 00000
VCID: 366393C7128A968EB7-5140
WAULC68EX5A040950 AUZ6Z0D0234637
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1612
Coding: 11848
Shop #: WSC 63351
VCID: 72EB6FD73E62CAAE5B-4B1E
Subsystem 1 - Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0205
4 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
01561 - Rear left door
59-10 - Can't Unlock - Intermittent
End-------------------------(Elapsed Time: 05:32)--------------------------
