Results 1 to 19 of 19
    Jun 14 2007
    2000 S4
    Connecticut
    Question Another Depo City Light Wiring Thread
    There are a bunch of half finished threads out there talking about how to wire city lights in your Depo housings. Reading this page, it makes me think that the most simple way to do this is to take the power from the auto-leveler. The idea of getting the power at the turn signal to me seems like more work and this is all internal to the headlights. Can anyone confirm what has to be done? From reading that AW post, I an interpreting it as I have to essentially take the 12V switched power from the blue feed line (there is also a black, and brown wire also), and jump that to the Yellow and Brown wires that come out of the city light harness. Am I right? If someone with more knowledge would chime in that would be much appreciated!
    Thanks,
    Aug 30 2014
    United States
    Happy to help, mid oil change here lol. So first thing to establish is do you want the city lights to replace the parking light? Or run simultaneously, or run city lights on the first setting and parking lights + low beams on the second one.
    Each one can be done, I'll try to help whichever you choose. I did the last one.
    Aug 25 2012
    Elmore alabama
    I would like to hear both
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by Articus View Post
    Thanks! I'd like to do whatever is more simple :). If they're on all the time (with headlights on of course either in parking light mode or low beams) I don't care.
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Can somebody explain to me what city lights mean? Is that daytime running lights? What the frick is parking light?
    Dec 09 2015
    neither here nor there
    Quote Originally Posted by wbrunner23 View Post
    In some European countries, if not all, the parking lights are the city lights, and the turn signals are ONLY turn signals. They do NOT double as parking/turn signals
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    The city lights are the little lights inside the headlight housing that lightly illuminates the housing. The parking lights are the turn signals. Well.....the same bulb, first "click" on the headlight stick. Bobkatkat has some great pictures in the random pick thread displaying the city lights
    Ah ya beat me to it, and with a better explanation none the less
    2002 Pearl/onyx S4 Avant
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    Thanks,
    Hey Mike,
    The easiest way I found to do it was to just wire it up to the blinker parking light. You need to get two of the headlight plug wires which simply click into the connector. Don't buy the European city light kit. The bulbs on the OEM e-codes are different than the depo's. You need two of these (2 per side):
    https://www.ecstuning.com/Audi-B5_S4...lights/ES4053/
    Edit: Mike use Mark P's write up. This is pretty good.
    http://ctny.audiworld.com/mark/s4/euros/install/
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    I wired mine in place of corner parking light. Pretty much just cut the wire leading to the corner light (first used test light to find correct wire) then ran that wire to the citylights. First click turns on citylights, second still fires headlights and keeps citylights on. Turns work as they should.
    Parking/citylights on
    Full headlights on.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Nov 02 2012
    Indianapolis, in
    Mmmmm casa.....
    A little off topic, but is your grille surround color matched or is it just a visual effect?
    Nov 10 2004
    Longview, WA
    In the first pic its black, the second pic was older when it was color matched. But the paint didnt hold up very well over time, so when I painted the mesh, I decided to also paint the surround black. Ill go back to color matched when I have my euro trunk painted. Good eye.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Jun 10 2010
    I wonder if these are worth anything to anyone. They're Valeo D2S E-Code harnesses from my old headlights.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Sweet, doing this now. I had a 10 pack of side marker bulbs and they fit. Hahaha.
    I have a pre facelift to facelift harness i made (top corner) that i will be depinning and pinning the factory plug on the car. Cutting the wire from the side marker plug and wiring it to the new pin.
    It would of been cooler on my pre facelift where the Daytime Running Lights where corner light.
    Sent from my Jailbroken iPhone 6s 9.0.2 using Tapatalk
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by Kruat View Post
    Which wire on the city light harness? Yellow? That's what I'm looking to achieve.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by S4 John View Post
    Hey Mike,
    Cool man thanks. What does that plug into? Which connector are you referring to?
    Oct 09 2012
    The main headlight connector to headlight housing. Pictured here with the white wire jamed into it. I thought this picture was self explanatory.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 09 2012
    My hood was open so I grabbed another pic.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Nov 10 2004
    Longview, WA
    I don't recall, and my car is in storage. But it's just two wires on the citylight harness right? Then it really doesn't matter as the other goes to ground.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Jun 14 2007
    2000 S4
    Connecticut
    Good news.. Figured out the wiring . Thank you to John who linked me to the ECS product above and King who took the picture of the back of the headlight plug which made the job very simple once I got the parts from ECS. I forgot that my buddy had already tapped into the parking light wire on each side a few years ago, but did it as a quick job with whatever he had around to get them done so when I removed the headlights one time I had to cut the wire because he went straight to the city light harness with the wire running into the headlight housing. The much cleaner way to do it is what John linked me to above which is adding the pin to the headlight plug so you splice into that wire which will allow you to remove the headlights just fine. I'm much happier having gone this route the second time around.
    I also used this write up when I wasn't sure why I couldn't get the pin all the way in.. Go figure, there is a lock!
